Electrical Failures, All main power feed failures, and fuse box
names and fuse names, revealed.
![]() Warning: Do not short the RED plus battery to ground ever, or jumper a battery backwards or the battery will explode, shooting acid in to your eyes or worse. (ask the tow man, see him cry) Always remove the NEG battery term first and put back last or risk the above fate. NEVER DO's Do: The first test on the electrical system, is to make sure the head lights and the blower (heater) work prefectly and the Head lights are not dim. Clean the battery terminals ! Clean them , then make sure the other ends are tight. (both go to starter and both must be clean and tight) See fuse locations. Make sure your battery is charged. 12.6vdc is normal. lower indicates it is real cold or discharged. See my DMM meter page. See my tools page. Learn to use your VOLT meter , a.k.a : Digital Multimeter or DMM , abbreviated. (volt ohm meter or VOM )(offsite) The best DMM in the shop, is one with a duty cycle function (for tuning idle controls) and even better is the Amp clamp meters. Check all fuses ! FIRST ! Test them. Including Fuse block #1 next to the battery on the Right fender, and the other is above the drivers left knee, Box 2. (LHD) {left hand drive car} In the salt belt? look under the box 1, now, or you will pull your hair out later. What is the SALT BELT ? I never just look at a fuse, (if it looks bad?, it is , but if it looks good? , it can be bad) use an Ohmmeter to check continuity. (or do a voltage drop test on the fuse, key on, live! 12v left side and 12v right side, good, I have no voltage drop you say, and grin. This is a rubber meets the road test, live and real. If the Head lamps fail or are dim, FIX THAT FIRST ! Head lights are HOT at all times, if they fail, the problem is the main power feed is bad. (or battery issues) If your battery will not hold a charge , there are 3 reasons , one; is a bad battery , the second; is phantom drain, and the last is a bad Alternator. (or bad wiring) Only FATE rules here. To find out which it is? , is very simple and in the correct order:
Battery suspicions? Replace the battery with a known good battery (barrow wifes?) or take it down fully charged up, first, to any auto store for a free load test. Or buy the load tester for $20 ( @ Harbor freight ) Hint: after charging a battery , let it rest for 4 hours, (so the surface charge, mixes inside and stabilizes) then read the State of charge tables, use the volt meter to see if battery even does charge fully. Keep in mind, the starter needs a strong battery to crank the engine, about 100 amps, and after is starts the battery needs to be at 13.3v or more, below 10vdc the ECU and friends, can go nuts or off line. The best idea of all, is a dash mounted voltmeter wired to the key on , ignition switch, on pin. Global to all EFI pages, or electrics is "Wires are bad ?" I'm blowing the IG-COIL or FI fuse, how do I find my short?'' ( + see the how to find, parking lamps shorted example at the end) My dash lamps are burned out, or gauges , or speedo needs to be pulled. ( includse lamp sources and P/N) Learn to to Check for power feed voltage drops or bad grounds. Suzuki spec of the drops are 0.5vdc MAX.
If you have a volt meter you can check the state of charge on the battery at any time. Here is the Chart for discovering your batteries STATE OF CHARGE , SOC. See line #9 the 80 degree ambient temperature reading must be 12.65vdc (rested 1 hr) or the battery is discharged. Use your ambient temperature, to find your voltages. Cab fuse boxes: Called fuse block 2. Above left (LHD) drivers knee. ![]() LHD = Left Hand Drive! CAB fuses are above left knee (left hand drive) Fuses that look blown out are, some that look good, are bad (tiny cracks). Use a DMM , set the dial to Resistance (ohms low if it has that or Rx1 or Rx20) The fuse should read the same (zero ohms) as crossed meter leads. The pre April 1989 Geo Trackers had real 89 Suzuki Fuse boxes and were made in Japan , before the CAMI plant opened in Canada. GM GEO TRACKER 89/90 fuse box. (post April 89) see next photo for pre April 89 Geo made in Japan Suzuki 89/90 fuse box photo The 91 to 95 , Tracker Sidekick fuse boxes. ( and 89/90 Suzuki too) The 96-98 GEO Fuse cab box. (98 may vary slightly it has more fuses) check the cover for ID and spare fuses inside. 96 Suzuki actual cab fuses (odd numbers ) 96 Suzuki fender fuse box #1 (main) 99- 2004 Vitara or Tracker fuse box 2 (front), with Fuel pump relay location Hints: ON BAD WIRING There are no simple answers, you must do tests and measurements in order to isolate problems, if you do not have any basic tools and a Digital Multimeter , you will just be guessing and buying expensive parts in vain. If your car is OBD2 then things get a lot easier for engine running issues. In the USA, all 1996 and newer cars can use: (over the counter cheap scan tools (full scan tools) As cheap as $15. Got BAD WIRES ? LOOK HERE FOR BASICS Please, get a meter (any) and learn 2 things, how to measure voltage and how to measure resistance . Get a nice cheap DMM. Walmart , Home Depot and all auto stores sell meters. If you have problems with injection or any other electrical part, be sure to inspect all ends of wires , cables and connectors , at the slave devices or at the ECU end. Make sure the insulation of said wires are not damaged, from previous engine pulls. or hackers wiring in junk, like remote starts or alarms with no wiring skills. (common) Rodent damage, ? There are 5 checks.
USE A DMM meter to check for Continuity , Shorts and bad wiring insulation. The above is SOP , standard operating procedures. Never buy a car that has obvious wire hacking, near the ECU, or engine harness. Take the cource on electrical here, there are no limits, only a desire to learn. PS: Good luck finding new Suzuki connectors..... Near impossible..... (find a wrecked car and remove the whole harness while you can, no yards in my town have any Suzuki's at all and soon to be less due to Chapter 11 filings) rev 9; 8-1-2013, add(moved) badwires section to here. Revised 5-14-2014 |
