How to buy a Speedo Cluster (head) Aka: I/P CLUSTER (Instrument Panel) ![]() There are many failure modes. (Watch out for Prev. owner removing the CEL lamp and or holder use a flash light to see which port is CEL or what?)
Pull center cable from the sheath of main cable, from below, did you get 1/2 a cable? See, it snapped? If the speedo needle bounces this is a bad/kinked cable, to prove it, pull head, spin speedo rear port ccw, by hand or drill ,if smooth and quiet , it's a bad cable. How to remove this CLUSTER , is shown here. >> (if the spin test CCW, under car at the Tranny , fails? do this) CCW= counter clock wise. Index
SPEEDO needle symptoms: Bouncing needle with no sounds, is a bad cable ( or kinked, or misrouted causing same) Bouncing needle with loud head noises, is bad head. test head pulled with drill motor spun , CCW. The needle fell off, that is the cups/cone crash , bad bushing in the speedo clock that did that, a bad speedo clock guts. Key features when buying:
![]() Slide shows: SPEEDO HEAD's ( adding new photos now) WANT A USED HEAD? Trick one, match the connector count and pin count on the rear, first. or you just bought the wrong speed. (fleabay rule) My page is to help GET THE RIGHT HEAD. Common failure #1: if the speed needle is dead and odometer is dead ,then the cable is snapped or end key on cable bottom end has snapped (rare transfer case speedo drive gears busted) MIXING PARTS or other Tricks ? Next , I mix speedo guts. I get 2 or 3 old clusters and mix part. If all you need is just the VSS working (the odometer usually never dies.) Just asked this, good question Use a TOM TOM or the like for speed and distance , hell with the speedo. DEFEATING THE SPEEDO so my VSS works only, I dont need a working needle or odometer : (and have peace and quiet.) I have GPS for speed. Dismantling . Cluster on the bench.
If you car is a 1980 non JLX this VSS bracket, part, may be missing.http://www.fixkick.com/sensors/tests/vss-testing.html ![]() More SPEEDO guts. (details of the insides) Photo 2 Done not remove the needle on good speedo's ,defeating it , is another matter see above. Below is circa 1991 ![]() VSS: (in the speedo head) If the VSS sender breaks ( or cable) the engine will never run right (fueling) while moving again. This VSS sensor is NOT OPTIONAL. sorry , NOT! This causes DTC code 24, when that happens car goes to LIMPHOME mode: (MPG as low as 15 mpg ) You must drive car to get 24's When Limphome (Suz calls it FAILSAFE) the car runs RICH as a pig, ignition retarded, no more cruise control , no more TCC lock up, a very unhappy 4-speed automatic transmission , and a dead EGR, dead, EVAP sys. and Deceleration fuel cut . (The O2 sensor monitor might fail too) VSS is NOT AN OPTIONAL SENSOR, not even close. The VSS clicks 4 times per Speedo cable resolution , check this an DVM ohm-meter or continuity tester ,or simple test light. The Speedo heads states the rev per mile, and is a hidden lable, inside: 5speed : sticker " 1026 Rev = 1 mile" Rev= revolutions (lens off front of cluster ,see markings) working backwards from 1026, the Rear prop shaft turns, 3.8 times more per mile. or 3898.8 rev/ mile , and the rear axle (going straight) turns 5.125 less. at 760 Rev/mile see, my TIRE Rev per mile tables and math here. Stock tires can vary by style , passenger tire and off road types. same size. but.... 744 is the rule here. EG: 27.1 Diameter times Pi π (3.14 {3.14159265} ) is 85.1 circumference. So, Tire rev per mile , is 5280 feet times 12" 63360 inches per/ mile divided by 85.1" and you get 744 rev / mile . (not hard math at all) I see many companies list 744. (and will be less as it wears down) ( this is the revolutions per mile and the transfer case speedo gear set must follow this rule, there are 3 factory speedo gears. for the 3 axle /tranny combonations.) VSS is just a simple reed switch. Any will work fine, get one at Radio Shack. Tiny is best. Solder then new one in, cut the old one out. I do have GM / GO P/N for these gears but GM is a bit dead now. (sold GEO parts to some other company, so good luck figuring that out) Speedo gear choices table:
Do not expect 6 tooth gear to fit any transfer case, IMO,I think it will not. This fits 2wd 5speed tranny tail shaft only. (I never tired it) I do not have the Rev count tags for the special speedo's above. As you can see the speedo will read a tad low, at 1 mph, but as you go real fast and tires expand, the tires, may hit spec 760 Rev/per/mile. ( my theory) This table will allow you to predict the speed change with speedo gear changes (the speedo gears are plastic) The ratio (speedo-gears) above, is the ratio from the rear prop shaft to the Speedo cable. Suzuki part numbers for these gears, are as per below. keep in mind transfer case must be pulled to swap the drive gear. so, try new cable gears. I am not sure if the pitch on the teeth must match.? drive to driven.? Suzuki P/N , all: Tooth count: and Suzuki P/N (part number = P/N) Drive 5--- 29411-60A01 drive gear is mounted to tranny tail shaft. very hard to replace for sure! Drive 7--- 29411-60A11 " " " Cable 19--- 29421-60A01 cable gear is at end of cable. (easy change) Cable 22-- 29421-60A31 Cable 24-- 29421- 60A12 Suzuki's might have a gear kit, ask them. ( most say , no) So , if you are running big tires. With 5 speed or 4 speed, you can not speed up the speedo. No options for that. If running the 3sp A/T , you and try the Drive 5 and driven 19 pair set. to spin the Speedo the fastest (unless you already have this set.) Remove the 22 gear and put in the 19 gear. changing the ratio to 3.8: 1 The speed will be faster now , faster indication than real. Indicating, about 4% higher than actual, if tires before gear change, made speedo 10% lower than actual. A GPS speedo is less trouble. The common ratios of rear axles. (or matching fronts with 4wd) 89-98 Tracker/Sidekick Gear Ratios (North American Models) 89 Sidekick 2D 1.3L Carb 8V SOHC 5 speed man. 5.625 89-95 Sidekick 2D 1.6L TBI 8V SOHC 5 speed man. 5.125 89-95 Sidekick 2D 1.6L TBI 8V SOHC 3 speed auto 4.625 92-98 Sidekick 4D 1.6L MPFI 16V SOHC 5 speed man. 5.125 92-98 Sidekick 4D 1.6L MPFI 16V SOHC 3 speed auto 4.30 92-98 Sidekick 4D 1.6L MPFI 16V SOHC 4 speed auto 5.125 94-98 Sidekick 2D 1.6L MPFI 16V SOHC 5 speed man. 5.125 94-98 Sidekick 2D 1.6L MPFI 16V SOHC 3 speed auto 4.30 94-98 Sidekick 2D 1.6L MPFI 16V SOHC 4 speed auto 5.125 96-98 X90 1.6L MPFI 16V SOHC Auto or man. 4.625 96-98 Sport 1.8L MPFI 16V DOHC Auto or manual 5.125 Cluster P/N lists by Suzuki. ![]() ![]() ![]() Custom speedo shops ( yellowpages) can correct your speedo, but it will be an expensive trip. Best is just put a sticker in the SPEEDO that says. Error 110% and drive accordingly. Or buy a GPS speedo, but the odometer will always be off with large tires. NOISE: The speedometer/Odometer (I'll call it a speedo, for short) The cables Spins at 878 RPM at near 60 MPH. (about 1/4 the speed of the rear axles at all times.) (so, 1 mph is about 14 RPM) so, faster is more noise.... (if the noise from the head stops ,when you drop off either end of the main cable attachments , the head is bad.) You can drop either end (1 at time and drive.), and find out ,if in fact only the cable is bad.(all this is obvious, but I feel compelled to state this and cover all fail paths) The cable can fail many a way, it can snap, or dry out, and make noise, then when really dry and really sticking , it snaps , and all is quite and a dead speedo head. (needle and odometer dead)
Best link: on Speedo facts. There is a very specia,l no migration grease used, high temperature. Finding some for sale is , near impossible. Keep in mind, for real shops, in many USA states, resetting an odometer, is a felony. (if your's is missing, there will be no proof , of who or how it was done, no evidence) Obviously, owners can swap speedo clusters, all day, any day. (in the dark , no witnesses.) LOL. But don't make the mistake of asking others to do that.... dig? ver 6; (edits for noise) 10-1-2013 |
