| Suffix |
YEAR |
Body
ID |
CAL/ FED |
Tacho- meter ? |
Comments |
Options Pins? |
Doors |
Tranny blank=any |
| 60A30 |
89-90 |
base |
FED |
no |
No cruise option |
No vss ? |
2/4 |
no mention |
| 62A10 |
89-90 |
base |
CAL |
no |
No cruise option | No vss? |
2/4 |
of tranny |
| 61A20 |
89-90 | JLX | fed |
yes |
w/power steering
uses 91 speed meter, cruise head with vss |
yes, vss |
2/4 |
89-91 |
| 62A20 |
89-90 | JLX | CAL |
yes |
ditto above (CAL = no nag switch) |
yes ,vss |
2/4 |
| 63A80 |
91 |
JX | fed |
yes |
Y |
2/4 |
| 71E00 |
91 |
JX | fed |
y |
Y |
2/4 |
| 65A30 |
91 |
JX/JLX | cal |
y |
Y |
2/4 |
| 72E00 |
91 |
JX/JLX | cal |
y |
Y |
2/4 |
| 63A40 |
90 |
JS |
FED |
No |
N |
2 |
| 63A60 |
90 |
JS |
CAL |
N |
N |
2 |
| 63A10 |
90 |
BASE |
FED |
N |
N |
2 |
| 63A20 |
90 |
BASE |
CAL |
N |
N |
2 |
| 63AC0 |
89-91 |
JS |
FED |
y |
Y |
2 |
| 65AC0 |
89-91 |
JL |
FED |
n |
2 |
| 63AD0 |
89-91 |
JS |
CAL |
y |
Y |
2 |
| 67AA0 |
89-91 |
JL |
CAL |
N |
2 |
| 60AD0 |
90 | JX/JLX | FED |
y |
N |
2/4 |
| 65AD0 |
91 | JX/JLX | FED |
yes |
my new speedo, swap |
Y |
2 |
| 62AB0 |
90 | JX/JLX | CAL |
y |
N |
2/4 |
| 67AB0 |
91 | JX/JLX | CAL |
y |
Y |
2 |
| 67A20 |
91 |
JS |
FED |
n |
y |
2 |
| 67A30 |
91 |
JS |
CAL |
n |
y |
2 |
| 67A90 |
91 |
JL |
FED |
n |
y |
2 |
| 68A00 |
91 |
JL |
CAL |
n |
y |
2 |
| 65AD1 |
92-93 |
FED |
y |
Y |
2 |
| 67AB1 |
92-93 | -- |
CAL |
y |
Y |
2 |
| 63AA1 | 92-93 | FED |
No |
2wd only | Y |
2 |
| 63AB1 | 92-93 | CAL |
N |
2WD only | Y |
2 |
| 71E11 |
92-93 |
FED |
yes |
2/4wd First mention
of tranny at 4door only body |
Y |
4 |
M/T |
| 72E21 |
92/93 |
FED |
y |
2/4wd |
Y |
4 |
A/T |
| 72E01 |
92-93 |
CAL |
y |
2/4wd |
Y |
4 |
M/T |
| 72E21 |
92-93 |
CAL |
y |
all have |
4 |
A/T | |
| 71E21 |
92-93 |
FED |
y |
vss now |
4 |
A/T | |
| 71E80 |
94-95 |
FED |
y |
16 x 13 |
4 |
M/T |
| 72E80 |
94-95 | -- |
CAL |
y |
16 x13 |
4 |
M/T | |
| 71E70 |
94-95 | -- |
FED |
y |
16 x13 | 4 |
A/T | |
| 72E70 |
94-95 | -- |
CAL |
y |
16 x13 | 4 |
A/T | |
| 60AM0 |
94-95 | -- |
FED |
y |
16 x13 | 4 |
M/T | |
| 61AM0 |
94-95 | -- |
CAL |
y |
16 x13 | 2/4 |
M/T |
| 60AN0 |
94-95 | -- |
FED |
y |
(over drive lamp?) |
16 x13 | 4 |
A/T |
| 61AN0 |
94-95 | -- |
CAL |
yes |
16 x13 | 4 |
A/T | |
| 68AB0 |
96-98 |
No |
no/ ABS |
13x10x16 |
2 |
| 68AA0 |
96-98 | No |
yes/ABS , speed clock same as AB0 |
13x10x16 | 2 |
| 79EP0 |
96-98 | FED |
Y |
13x10x16 | 4 |
| 79EV0 |
96-98 | CAL |
Y |
13x10x16 | 4 |
| 69AD0 |
96-98 | FED |
Y |
NO ABS |
13x10x16 | 2/4 |
M/T |
| 69AB0 |
96-98 | FED |
Y |
W/ABS |
13x10x16 | 2 |
M/T |
| 69AC0 |
96-98 | Y |
4DR A/T NO ABS |
13x10x16 | 4 |
A/T |
| 69AC0 |
96-98 | Y |
4DR A/T W/ABS |
13x10x16 | 4 |
A/T |
| 77EN0 |
96-98 | Y |
4DR 1.8L Suzuki only SPORT |
4 |
