Sensor name |
Alt. name |
Function
Sensor or device. Items in RED are critical in starting the engine. |
Location (typical) 89-95. |
IAT |
ACT |
Air temp, or Intake Air
Temperature sensor. IAT |
In the
intake tube or the intake
manifold plenum, not critical , it fine tunes! |
ECT |
WTC |
Engine Coolant
Temperature senso ECT |
Screws
to water jacket on block or water outlet of thermostat housing. |
MAP |
Manifold Absolute Pressure. Critical after Starting. MAP |
Connected
to intake manifold plenum. Vacuum sensor, electronic. |
TPS |
Throttle (valve)
Position Sensor TPS
with switch |
On the
end of the Throttle Body butterfly shaft. A Variable
resistor. |
O2S |
EGO |
Exhaust oxygen sensor O2S ( HGEO = heated ) |
Located
in exhaust manifold (on old cars), new cars have 2
or more |
VSS |
Vehicle Speed sensor. VSS |
Just
a rotation counter on the speedo cable. Cars speed is measured. |
CMP |
CAS |
CAM angle
sensor. CMP |
Located
in the old Distributor or on Cam shaft end , on newer cars. |
CKP |
CPS |
Crank position
sensor CKP
(96 an newer) |
Located on
front of oil pan and reluctor wheel behing crank belt cog wheel. |
EGR |
Exhaust Gas
Recirculation devices EGR |
Located
on Intake manifold and is not a sensor (but is,on somecars ) |
MIL |
CEL |
Maintenance Indicated Lamp ,Check Engine Light | On
dash Lamp shared with SES.
Service engine soon. |
PCM |
ECM |
Power train control
module PCM EFI
controller (suz) |
89-95
is behind left front speaker. aka:ECU,ECA,ECC, BRAIN or Puter |
MAF |
AFS |
MASS Air Flow, Sensor MAF |
Located
on Air tube
between Throttle body and the Air cleaner. 95 and newer vehicles and
all 16valve engines. NEVER touch the HOT WIRE! |
ISC |
IACE |
Idle speed Controller (a output
actuator
device) ISC |
ECU
Idle control
valve. Electric modulated Idle control device. |
IAC |
IACT |
Idle Air Control IAC usually a thermo device |
Located on base of Throttle body
"TB" both MPI and TBI |
Misc. |
Injectors, Ignition
coil, Fuel
pump, outputs |
Starter monitor, Battery
voltage monitor. |
MPI |
TBI
Multi Point Injection and
Throttle body Injection. |
16v is MPI and 8v engines
are TBI . Vastly different EFI designs. |
EVAP |
Evapoative Emissions |
Large black charcoal
canister and vacuum control purge valves. |
TCC |
Torque Converter Clutch
(solenoid) TCC |
varies by year, some PCM's
(newer) have no relay ,ECU has direct drive. |
TCM |
Transmission Control
module, 4speed only |
located high in dash above right
knee behind ignition key level. |
THE DUMMY SPARK PLUG: (get one) ![]() To test for spark , you should have a dummy spark plug connected (see above photo). Never short out any spark plug top terminal to ground directly or leave it open circuited. You MAY damage the ignitor device.[ a huge transistor ] or in newer cars the ECU will be blown out. ( integrated Ignitor). < best reason to not do it! ( the ignitor, is part of a High Energy Ignition, that which generates up to 50,000 volts, to spark the plugs ) The above is Sold in all Automobile parts stores. It is dirt cheap. Some guys just weld a clip to a new spark plug. RESPECT: ( this is high voltage and can be dangerous , unlike a lawn mower engine with 5 times less power) 50,000 volts, don't touch it while cranking or running the engine. It will be very painful! Even dangerous if it passes through your heart ! |
