07-13-2020, 05:26 AM
Just got a Tracker yesterday. 1995 tintop. 16 valve engine, manual transmission. A/C and power steering.
I'm doing some of the suggested maintenance listed on the FixKick page (timing belt, water pump, inspect keyway on crank nose for bottom timing belt pulley, valve clearances etc).
I've got a parts list going at Rock Auto. Gates belts and water pump, Fel-Pro Seals, etc.
Replacing radiator, what's the best brand?
Can't find distributor seals.
I've got a Factory Service Manual on order, does it include parts diagrams? If not, where can I find parts diagrams?
The 17mm bolt for the bottom timing belt pulley broke free without a tremendous amount of force. However, the bolt backed out about half an inch and won't go any further. I don't want to use too much force and risk shearing the bolt off. I've used penetrating oil and heat, still no go. Any suggestions?
Thanks in advance.
Great site and forum, lots of useful info.
Thanks in advance.
