ah yes, pressing issues, LOL
im not sure, but if the stroke is as long as the main shaft, yes. well 3/4 of that.
im no sure on the kent tool
the last page in the fsm calls out the rear bearing set tool,.
most of the tools only allow force to the bearing inner hub, this i good but any pipe can do that. these all bottom out , no magic gap as i call it.
only one tool is needed, that is the one that sets the magic gap.
the middle bearing press step
fitting bearing #8, with tool 18011. tool.
all other bearings, have a boss to land on, (a cake walk)
page 24, step 11. see that here.
http://www.fixkick.com/tranny/sidekick_d...manual.pdf
7a22 actual, FSM page.
with this too , missing, i used my feeler found it at .005
then on assembly, pressed it to .005 play, it run like dream.
bearing 8 is the only hard bearing in the box.
of coarse bearings off is easy, they are not to be used, so just yank them off, no matter. i used gear pullers. then the get the trash bin.
going on, i never hit them unless it's the inner bearing hub, never outer rim, or race cage sure.
i use pipe that fits good, even metal if using a press. any pipe can work that fits good.
![[Image: magic.jpg]](http://www.fixkick.com/tranny/images/magic.jpg)
my cheat sheet.
like it?
my cheat sheet.
like it?
![[Image: 3_26_08_14_11_59_12.jpeg]](http://www.fixkick.com/bbs2/Suzuki-bbs/gallery/3_26_08_14_11_59_12.jpeg)
