power steering
Well the steering wheel is sometimes to hard to turn stopped. It is abrupt like it turns a bit easy and then hard for a little then easy again and hard after. There is a squiking sound when it gets harder.
No leaks. The level is proper. I cleaned the bottle and the filter. Changed the fluid there. But the problem is intermittent and only when stoped. Driving is fine.
All the advise appreciated.
Thanks
Suzuki Esteem 2002, Auto.
1: engine RPM below 800 hot.
2: belt slips.
3: pump bad? or just worn and tad weak.
I will exclude the first to as the belts are tight and the rpm are right.
I Wil. Focus on the pump. Looks it is easy to take it out. Can it be rebuilt easy as well?
Thanks
