power steering - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: power steering (/thread-power-steering) |
power steering - Vitalie - 03-24-2015 Well the steering wheel is sometimes to hard to turn stopped. It is abrupt like it turns a bit easy and then hard for a little then easy again and hard after. There is a squiking sound when it gets harder. No leaks. The level is proper. I cleaned the bottle and the filter. Changed the fluid there. But the problem is intermittent and only when stoped. Driving is fine. All the advise appreciated. Thanks RE: power steering - fixkick - 03-24-2015 1: engine RPM below 800 hot. 2: belt slips. 3: pump bad? or just worn and tad weak. RE: power steering - Vitalie - 03-24-2015 I will exclude the first to as the belts are tight and the rpm are right. I Wil. Focus on the pump. Looks it is easy to take it out. Can it be rebuilt easy as well? Thanks |
