very good
the noise is forward,its not the shaft splines i can see they are clean and sharp and good, the look.
you can here it make noise by hand , that is bad. but what gear, did you use 4th like i said, this locks the tranny up, front to rear, and the clutch is locked to the flywheel.
in this mode, 4th only the 4th gear dogs, are all play, every bit and must not have any..... you need to post the cars status at each video. I presume rear wheels off the ground.
and the trans mission status, and (nobody in drivers seat) right>?
play on axles are normal !, but yours is crazy too much... wow.
but I cant see tires, i they move, that easy, if yes, ok, if not bad axle.
you tests pass. they look good and the play is not added top by hand on end of trans shift, all good
conclusion the 5sp was in neutral or not in 4th gear. so play is normal.
the rear axle is gone.
do tell trans mode, ??? please.
4th gear locks the front 4th gear dogs
the only play in this mode, is the clutch disc, hub spine, or the clutch disc springs (shock springs) are gone bad or broken up)
4th gear
see part 38 this slides over syncrho#41 and locks to part #1 rear dogs.. its not 1:1 locked up front to rear, we all it 4th gear but is not gear, just a lock up,
ignore 4wd warning, the main shaft on yours is very long.
![[Image: 5thGear.JPG]](http://www.fixkick.com/tranny/5thGear.JPG)
my guess is your rear axle side gears (and or spider gears) are toast.
but i cant see the tires, so is just a guess.
to show play, one most see both ends at once. (axles) on axles 3 end, Left /right and pinion. all at once.
normal axle pinion play is about 1/8" -1/4"
FSM
http://www.acksfaq.com/96-FSM-v1-4b-pdf.htm
the normal pinion to ring gear play is total backlash is .015" max. (just the ring/pinion)
the remaining play is the totality of side gears, and there pins, and the actual axle spline play. added up, they stack up.
all answers stock axles, no lockers or other parts , in there, like LSD or ?
the worst axle is the Detroit locker with 45 degrees of play. this is not that. (they have a loose, locker setup)
mine is, 1/4" play; rotational , tires on ground, in neutral. at rear axle flange.
now.
my axle is stock open axle, no LSD< no other closed lockers of any kind, just gears. diffr.
4th gear
FSM
now.
