Trans Modulator replacement
Thanks to all the great info and discussion on this site, I have procured a new purple strip trans modulator.
It is the first step we are taking to assist with the high/harsh shifting that has cropped up in the '89 sidekick.
I did observed some of the FSM diagrams on this site as well.
My main question: Has anyone replaced a modulator and if so, could describe the process?
I have the correct 30mm service wrench. I am also looking for any guidance on the overall process and any items of note/to watch for during the process.
Appreciate any info, thank you.
(09-27-2021, 06:28 AM)lemurh Wrote: Thanks to all the great info and discussion on this site, I have procured a new purple strip trans modulator.
the thin wrench
and new 0-ring and use grease on it as inserting the ring.
that is it.
this sensor/actuator tells the Transmission the load on the engine so it can shift correctly
good luck to you .
the thin wrench
that is it.
good luck to you .
Thanks for the confirmation!  Reading through the FSM posts outlined a lot of other activities, much appreciated.
