Trans Modulator replacement - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Trans Modulator replacement (/thread-trans-modulator-replacement) |
Trans Modulator replacement - lemurh - 09-27-2021 Thanks to all the great info and discussion on this site, I have procured a new purple strip trans modulator. It is the first step we are taking to assist with the high/harsh shifting that has cropped up in the '89 sidekick. I did observed some of the FSM diagrams on this site as well. My main question: Has anyone replaced a modulator and if so, could describe the process? I have the correct 30mm service wrench. I am also looking for any guidance on the overall process and any items of note/to watch for during the process. Appreciate any info, thank you. RE: Trans Modulator replacement - fixkick - 09-27-2021 (09-27-2021, 06:28 AM)lemurh Wrote: Thanks to all the great info and discussion on this site, I have procured a new purple strip trans modulator.the thin wrench and new 0-ring and use grease on it as inserting the ring. that is it. this sensor/actuator tells the Transmission the load on the engine so it can shift correctly good luck to you . RE: Trans Modulator replacement - lemurh - 09-28-2021 (09-27-2021, 07:00 AM)fixkick Wrote:Thanks for the confirmation! Reading through the FSM posts outlined a lot of other activities, much appreciated.(09-27-2021, 06:28 AM)lemurh Wrote: Thanks to all the great info and discussion on this site, I have procured a new purple strip trans modulator.the thin wrench |
