12-27-2015, 05:59 AM
I've got the top loose by the vents, and bottom loose by the ashtray and lighter, but it is solidly fastened by the heater controls!
How do I remove heater control panel 89 Tracker?
just the panel.
ok the panel is cable controls, has 3 cables, and must be removed first. or disconnected on the ends first. http://www.acksfaq.com/96-FSM-v1-1a-pdf.htm the 96 is near same. at this point. page 14 remove ash tray, then..... linked off my dash pull page. controls.
12-27-2015, 09:05 AM
Hi: I had to replace the light behind mine. The stencil snaps out first. You need to get behind it with something thin, like a knife or small flat-head screwdriver. The screws are behind that.
-Hydro |
« Next Oldest | Next Newest »
