How do I remove heater control panel 89 Tracker? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: How do I remove heater control panel 89 Tracker? (/thread-how-do-i-remove-heater-control-panel-89-tracker) |
How do I remove heater control panel 89 Tracker? - shoalsgary - 12-27-2015 I've got the top loose by the vents, and bottom loose by the ashtray and lighter, but it is solidly fastened by the heater controls! RE: How do I remove heater control panel 89 Tracker? - fixkick - 12-27-2015 just the panel. ok the panel is cable controls, has 3 cables, and must be removed first. or disconnected on the ends first. http://www.acksfaq.com/96-FSM-v1-1a-pdf.htm the 96 is near same. at this point. page 14 remove ash tray, then..... linked off my dash pull page. controls. RE: How do I remove heater control panel 89 Tracker? - harryhydro - 12-27-2015 Hi: I had to replace the light behind mine. The stencil snaps out first. You need to get behind it with something thin, like a knife or small flat-head screwdriver. The screws are behind that. -Hydro |
