01-21-2016, 08:19 PM
nice having a shifter that is tight. easy to shift !
no starts
got spark? using a test spark plug? and check timing if way off the cam belt slipped'
if sparks good and the cam is not retarded, all g16s run on test fuel, spray fuel in a can. all do
and tells all is well engine/spark.
if that works attach fuel last ,
next? is the DLC (94-8v) next to battery diag pins jumpred , causing 12s go flash ? cranking for 5 full seconded, not 41 ,no 42
there are 3 inputs to ecu that cut fuel. 2 fo 3 are reported, and tps ground wire broken/cut . that also cuts fuel 100%
The ecu cuts fuel if it thinks(sic) for any reason the human driver is doing WOT, cranking, called secret unflood mode....(1/2 joking)
then 12vdc to pump (pink to ground)wire.
and last this.
is this a 2 door, if yes all love to fail the pump g402 hidden behind left rear tail light , per my pump page,
you can hear the pump spin for 3 second each key on
some are very quiet , take of gas cap, listen at neck to be sure(2 person test) some brands loud others nice and quiet.
the gauge is 20 bucks
test fuel is next. run now,even 3 seconds? sound nice? next
no starts
and last this.
