Code for Sidekick Sport
After solving the TPS code that generating several other codes, my 96' Sidekick Sport has only one code P0125 Insufficient Coolant Temperature for Closed Loop Control. Any ideas???
(08-10-2019, 07:40 PM)rasmeidirt Wrote: After solving the TPS code that generating several other codes, my 96' Sidekick Sport has only one code P0125 Insufficient Coolant Temperature for Closed Loop Control. Any ideas???
did you read the manual first. post #1 in this forum has the manual covering this.
125 code error, (it means) (as it told you)
thermostat is slow.
ECT reads wrong,
Closed loop mode very slow to happen. (o2 bad, or AFR bad for vast reasons)
(08-10-2019, 09:23 PM)fixkick Wrote: [quote='rasmeidirt' pid='11958' dateline='1565430010']
Thanks. It is already 100... Do you think the ones on rockauto.com fit the Sport??? In the scan tool it reads 194F full hot!.
Where to post pics???
[/quote]
Just one more question of the seal, the rocauto.com says 25281??
The Stant website says 27281??
STANT answered
quote
This are the same part the difference in the part number is packaging. Either of the numbers will work 25281 or 27281.
Thanks
(08-13-2019, 06:23 AM)fixkick Wrote: STANT answered
quote
Thanks
Thanks for your time. I did email them and the answer is Gasket are the same except for packaging.
So parts order is on the way from rockauto.com.
The code
(08-15-2019, 09:53 PM)fixkick Wrote: i see you are in Viet Nam,?,  this is good to post so helpers know where you are and where  parts are sold, not 12,000 miles away and expensive shipping and delays.
and you need to post with year car, 1996 to 1998.
some parts on this engine vary by year, range above, so, year MATTERS
My sidekick sport is 1996.
Toyota with 4x4 here is always too big to run cheap for me. Their parts are also expensive. Buying parts from Japan is also expensive, like https://www.amayama.com/en
https://www.megazip.net and even https://partsouq.com/.
The prices at rockauto.com are acceptable, but the shipping is huge. However it is still cheaper than from https://www.amayama.com/en, https://www.megazip.net andeven https://partsouq.com/.
(08-16-2019, 06:37 PM)rasmeidirt Wrote:
(08-15-2019, 09:53 PM)fixkick Wrote: please do your own shopping, in Viet Nam , I can never ever help you shop. ok??
