Code for Sidekick Sport - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Code for Sidekick Sport (/thread-code-for-sidekick-sport) |
Code for Sidekick Sport - rasmeidirt - 08-10-2019 After solving the TPS code that generating several other codes, my 96' Sidekick Sport has only one code P0125 Insufficient Coolant Temperature for Closed Loop Control. Any ideas??? RE: Code for Sidekick Sport - fixkick - 08-10-2019 (08-10-2019, 07:40 PM)rasmeidirt Wrote: After solving the TPS code that generating several other codes, my 96' Sidekick Sport has only one code P0125 Insufficient Coolant Temperature for Closed Loop Control. Any ideas??? did you read the manual first. post #1 in this forum has the manual covering this. 125 code error, (it means) (as it told you) thermostat is slow. ECT reads wrong, Closed loop mode very slow to happen. (o2 bad, or AFR bad for vast reasons) RE: Code for Sidekick Sport - rasmeidirt - 08-10-2019 (08-10-2019, 09:23 PM)fixkick Wrote: [quote='rasmeidirt' pid='11958' dateline='1565430010'] Thanks. It is already 100... Do you think the ones on rockauto.com fit the Sport??? In the scan tool it reads 194F full hot!. Where to post pics??? RE: Code for Sidekick Sport - rasmeidirt - 08-11-2019 Thanks. It is already 100... Do you think the ones on rockauto.com fit the Sport??? In the scan tool it reads 194F full hot!. Where to post pics??? [/quote] RE: Code for Sidekick Sport - rasmeidirt - 08-12-2019 Just one more question of the seal, the rocauto.com says 25281?? The Stant website says 27281?? RE: Code for Sidekick Sport - fixkick - 08-13-2019 STANT answered quote This are the same part the difference in the part number is packaging. Either of the numbers will work 25281 or 27281. Thanks RE: Code for Sidekick Sport - rasmeidirt - 08-13-2019 (08-13-2019, 06:23 AM)fixkick Wrote: STANT answered Thanks for your time. I did email them and the answer is Gasket are the same except for packaging. So parts order is on the way from rockauto.com. The code RE: Code for Sidekick Sport - rasmeidirt - 08-13-2019 RE: Code for Sidekick Sport - rasmeidirt - 08-16-2019 (08-15-2019, 09:53 PM)fixkick Wrote: i see you are in Viet Nam,?, this is good to post so helpers know where you are and where parts are sold, not 12,000 miles away and expensive shipping and delays. My sidekick sport is 1996. Toyota with 4x4 here is always too big to run cheap for me. Their parts are also expensive. Buying parts from Japan is also expensive, like https://www.amayama.com/en https://www.megazip.net and even https://partsouq.com/. The prices at rockauto.com are acceptable, but the shipping is huge. However it is still cheaper than from https://www.amayama.com/en, https://www.megazip.net andeven https://partsouq.com/. RE: Code for Sidekick Sport - rasmeidirt - 08-27-2019 (08-16-2019, 06:37 PM)rasmeidirt Wrote:(08-15-2019, 09:53 PM)fixkick Wrote: please do your own shopping, in Viet Nam , I can never ever help you shop. ok?? |
