Bracket screwed up
Im reassembling my intake manifold and suck for the top of my engine (94 Sidekick JLX, 4 door, 4wd, 4 door, ,fed) and I cant remember where this L shaped bracket goes.... I took the manifold off to clean out the EGR ports (which is done) and I just cant remember...
Attached Files Thumbnail(s)
those are the 2 engine pulling brackets.
on frontĀ  right and 1 rear left, (drivers seat perspectives)
to the corner manifold bolts/stud mounts.
here is my 97 , dropping in off those 2 brackets OEM stock
https://fixkick.com/engine/97-motor-pull...ge_47.html
No that rear left bracket it still on. I never took it off. I only took off the intake manifold, fuel rail, egr, and throttle body (air intake tube too).
has to be on the right / passenger side somewhere. I have the passenger side front bracket ready to go on and the upper intake bracket too..
(11-25-2021, 04:18 AM)Beastcub Wrote: has to be on the right / passenger side somewhere. I have the passenger side front bracket ready to go on and the upper intake bracket too..
you forgot the alternator topĀ  mount??
pic 33 of your 97 engine pull.. this looks like the bracket. But where does it go? I didnt remove the alternator...
the manifold has a huge brace on its BOTTOM side to the frame. is that missing?
I will pull up the EPC, catalog of all parts on this intake.
next
there is a cruise control bracket unused .
the alternator , drawing shows same exact size and angle.
lacking that top part the alternator now lost its top triad mount.
part id 13 no less?
[Image: 539_alt.jpeg]
belt page drawing 3
https://fixkick.com/belts.html
