Bracket screwed up - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Bracket screwed up (/thread-bracket-screwed-up) Pages:
Bracket screwed up - Beastcub - 11-24-2021 Im reassembling my intake manifold and suck for the top of my engine (94 Sidekick JLX, 4 door, 4wd, 4 door, ,fed) and I cant remember where this L shaped bracket goes.... I took the manifold off to clean out the EGR ports (which is done) and I just cant remember... RE: Bracket screwed up - fixkick - 11-25-2021 those are the 2 engine pulling brackets. on frontĀ right and 1 rear left, (drivers seat perspectives) to the corner manifold bolts/stud mounts. here is my 97 , dropping in off those 2 brackets OEM stock https://fixkick.com/engine/97-motor-pull/HTML/image_47.html RE: Bracket screwed up - Beastcub - 11-25-2021 No that rear left bracket it still on. I never took it off. I only took off the intake manifold, fuel rail, egr, and throttle body (air intake tube too). RE: Bracket screwed up - Beastcub - 11-25-2021 has to be on the right / passenger side somewhere. I have the passenger side front bracket ready to go on and the upper intake bracket too.. RE: Bracket screwed up - fixkick - 11-25-2021 (11-25-2021, 04:18 AM)Beastcub Wrote: has to be on the right / passenger side somewhere. I have the passenger side front bracket ready to go on and the upper intake bracket too..you forgot the alternator topĀ mount?? RE: Bracket screwed up - Beastcub - 11-25-2021 pic 33 of your 97 engine pull.. this looks like the bracket. But where does it go? I didnt remove the alternator... RE: Bracket screwed up - fixkick - 11-25-2021 the manifold has a huge brace on its BOTTOM side to the frame. is that missing? I will pull up the EPC, catalog of all parts on this intake. next RE: Bracket screwed up - fixkick - 11-25-2021 there is a cruise control bracket unused . the alternator , drawing shows same exact size and angle. lacking that top part the alternator now lost its top triad mount. RE: Bracket screwed up - fixkick - 11-25-2021 part id 13 no less?
RE: Bracket screwed up - fixkick - 11-25-2021 belt page drawing 3 https://fixkick.com/belts.html |
