08-23-2014, 10:55 PM
(This post was last modified: 10-17-2015, 09:08 PM by fixkick.)
stall test fails cold
line pressure never checked!
still not one mention of a new filter yet..... why?
see post #5
6 months later the trans does that and not shifts late.
Threads: 26
Then my bad in describing. I used late/delay because it takes too long for the car too move but once in D it does all speed changes properly, and is only the first start of the morning. Takes about 5 minutes for car to move/engage. I did the road test and all gear change at the proper intervals. Need to do the manual and pump test.
Sorry for the confusion.
Javier
08-24-2014, 02:16 AM
line pressure never checked.
see post 5
still no new filter why? why do you think a pump can suck clean AFT thru a packed up filter.
why>????????
Threads: 26
R used to fail about a year ago. Now it engages instantly. Filter was replaced about a year ago. Can pump be replaced/serviced? Or is a whole new tranny? Like I said before, she shifts normally after that. Even if car off for 4+ hours or even more. Is just the very first morning run.
Threads: 26
Hello sir. Were you able to see my last post regarding the bad oil pump (if it happens to be bad and my options).
Thanks!!
Threads: 26
Mine is 94 but I'd assume is the same? Will do.
Good night!!
Threads: 26
When you remove oil pan there are a bunch of oil lines, are these the pressure test ports that you refer? I still need to the stall test. One of the possible reasons (not saying that is the cause) is if a ball somewhere in the valve body, was dropped. I changed this filter a year ago, but I don't remember seeing anything like that. Will check when I replace filter again.
Javier
Threads: 26
OK. I will. Going over what she does. She does moves after warming up and shifts normal at the specified speed intervals. Is only the first morning run.
Thanks!
