10-14-2017, 04:39 AM
Does anyone have a pic of a new/good woodruff key off vehicle part number 96051241 for 1996 geo tracker 2wd 2dr 5sp for crankshaft front snout?
woodruff key pic for crank 96 geo tracker
10-14-2017, 04:45 AM
posted here like 1000 times
this> off the timing cam belt pages http://www.fixkick.com/t-belt/damage/index.html endless photos of good, bad and ugly. good luck! (10-14-2017, 04:39 AM)bwhuntr Wrote: Does anyone have a pic of a new/good woodruff key off vehicle part number 96051241 for 1996 geo tracker 2wd 2dr 5sp for crankshaft front snout?
10-14-2017, 04:58 AM
10-14-2017, 05:59 AM
btw photos speak 1000 works,
as does the felt play in it. installed. (10-14-2017, 04:58 AM)bwhuntr Wrote:(10-14-2017, 04:39 AM)bwhuntr Wrote: Does anyone have a pic of a new/good woodruff key off vehicle part number 96051241 for 1996 geo tracker 2wd 2dr 5sp for crankshaft front snout? suzuki sells them. or can be had , by exact metric size. it fits tight, not sloopy, it only has 1 purpose to hold CAM time, until the bolt is set at 94ft/lbs on the dial. after that it of no use at all. till you off that cog again, for seal. only. or new pump. there are no dentes, its a woodruff semi circle, length, height,width, only matter, metric.. 5mm key the reason the keys go bad , is nobody reads the 1996 service bulletins... retro active to first G16. and the lack of flywheel lock tools,, on A/T cars. susuki p/n 08341-31059 $2 buyone and see the other measurements with calipers, 5mm key listed https://www.suzukicarparts.com/parts/ind...eid=214820
10-14-2017, 06:03 AM
it looks like all woodruff keys,
it is not truncated, its a full 1/2 moon key. B type. here http://69mustang.jphineas.com/wp-content...f_key3.gif cut with a fly cuttingwheel, is why. the stand off is here, seen in slide show posted before. http://www.fixkick.com/t-belt/snouts/ima...-close.jpg
« Next Oldest | Next Newest »
