woodruff key pic for crank 96 geo tracker - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: woodruff key pic for crank 96 geo tracker (/thread-woodruff-key-pic-for-crank-96-geo-tracker) |
woodruff key pic for crank 96 geo tracker - bwhuntr - 10-14-2017 Does anyone have a pic of a new/good woodruff key off vehicle part number 96051241 for 1996 geo tracker 2wd 2dr 5sp for crankshaft front snout? RE: woodruff key pic for crank 96 geo tracker - fixkick - 10-14-2017 posted here like 1000 times this> off the timing cam belt pages http://www.fixkick.com/t-belt/damage/index.html endless photos of good, bad and ugly. good luck! (10-14-2017, 04:39 AM)bwhuntr Wrote: Does anyone have a pic of a new/good woodruff key off vehicle part number 96051241 for 1996 geo tracker 2wd 2dr 5sp for crankshaft front snout? RE: woodruff key pic for crank 96 geo tracker - bwhuntr - 10-14-2017 (10-14-2017, 04:39 AM)bwhuntr Wrote: Does anyone have a pic of a new/good woodruff key off vehicle part number 96051241 for 1996 geo tracker 2wd 2dr 5sp for crankshaft front snout? Looking for pic "off" the vehicle, my key has indention on both side of the key, didn't if it was made like that. RE: woodruff key pic for crank 96 geo tracker - fixkick - 10-14-2017 btw photos speak 1000 works, as does the felt play in it. installed. (10-14-2017, 04:58 AM)bwhuntr Wrote:(10-14-2017, 04:39 AM)bwhuntr Wrote: Does anyone have a pic of a new/good woodruff key off vehicle part number 96051241 for 1996 geo tracker 2wd 2dr 5sp for crankshaft front snout? suzuki sells them. or can be had , by exact metric size. it fits tight, not sloopy, it only has 1 purpose to hold CAM time, until the bolt is set at 94ft/lbs on the dial. after that it of no use at all. till you off that cog again, for seal. only. or new pump. there are no dentes, its a woodruff semi circle, length, height,width, only matter, metric.. 5mm key the reason the keys go bad , is nobody reads the 1996 service bulletins... retro active to first G16. and the lack of flywheel lock tools,, on A/T cars. susuki p/n 08341-31059 $2 buyone and see the other measurements with calipers, 5mm key listed https://www.suzukicarparts.com/parts/index.cfm?make=Suzuki&year=1996&model=&searchText=08341-31059&action=oePartSearch&siteid=214820 RE: woodruff key pic for crank 96 geo tracker - fixkick - 10-14-2017 it looks like all woodruff keys, it is not truncated, its a full 1/2 moon key. B type. here http://69mustang.jphineas.com/wp-content/uploads/2010/11/woodruff_key3.gif cut with a fly cuttingwheel, is why. the stand off is here, seen in slide show posted before. http://www.fixkick.com/t-belt/snouts/images/snout-close.jpg |
