What fault is set for a power steering pressure sensor on a 1992 Sidekick 4door?
Just wondering. I replaced a power steering pump front pulley seal and noticed the pressure sensor wire was not connected. Should I connect it? Is there a fault I can look for?
the ps , sensor is steering overload
and cause ecu to raise, rpm from 800 to 1000 hot.
only happens lock to lock or at curbs force tire very hard into a curb/
Thank you.
your welcome and good luck and Cheers !
