What fault is set for a power steering pressure sensor on a 1992 Sidekick 4door? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: What fault is set for a power steering pressure sensor on a 1992 Sidekick 4door? (/thread-what-fault-is-set-for-a-power-steering-pressure-sensor-on-a-1992-sidekick-4door) |
What fault is set for a power steering pressure sensor on a 1992 Sidekick 4door? - Azplinker - 01-12-2016 Just wondering. I replaced a power steering pump front pulley seal and noticed the pressure sensor wire was not connected. Should I connect it? Is there a fault I can look for? RE: What fault is set for a power steering pressure sensor on a 1992 Sidekick 4door? - fixkick - 01-12-2016 the ps , sensor is steering overload and cause ecu to raise, rpm from 800 to 1000 hot. only happens lock to lock or at curbs force tire very hard into a curb/ RE: What fault is set for a power steering pressure sensor on a 1992 Sidekick 4door? - Azplinker - 01-12-2016 Thank you. RE: What fault is set for a power steering pressure sensor on a 1992 Sidekick 4door? - fixkick - 01-12-2016 your welcome and good luck and Cheers ! |
