virt.sig: 1993 Suzuki Sidekick, 193K miles, no issue what-so-ever. It is the 2-door JX model, 5-speed, 4WD. now VW powered.
ok, i could not remember which it was. sorry, so its still 5sp, (the a/t clutch packs can slip too. some are 100mm others are 140mm.)
the clutch needs to be rated for such high torque. i have no idea who makes such a strong clutch for a 5sp.
4speeds A/T?
sure they do ,but no 2door and 4wd. in usa, cept x90
the a44DE , at is renamed 03-72LE when it has a Suzuki BELL and a 4wd tail adaptor.
there are also the same for 2wd.
that link
http://bbs.zuwharrie.com/content?topic=113393.20
shows the many wild ways to fit different engines.
any machine shop can cut, weld and re balance a custom drive shaft if need be.
there are 3 drive shafts. but not one for 4speed 2 door, usa.
we have a 2door A/T with 2wd, but not 4wd. here.
the 2dr, drive shaft for 4wd , is sold all over Europe SE416 (vitara's_, and here as x90 suzuki but not here in sidekick(vitara)
also in all of , and Australia , and Asia.
this drive shaft is suz. p/n 27102-57b30
http://www.trademotion.com/parts/1995/Su...eid=215461
the vin tag has body code 68 for engine/trans combo. in those markets.
nice protect ! thanks for sharing.
[img]
[/img]
