Sidekick 4-door window seals
I have a '92 JX, 4 door sidekick.
The window seals (rubber seal between the glass and outside door window opening) are brittle and falling apart.
I have looked and not found replacements.
What have you done to replace or rebuild these seals to keep water and dust out of the door interior?
front inner:
83850-56B00
83860-56B00
front outer:
83810-56B00
83820-56B00
rear inner:
83870-56B00
83880-56B00
rear outer:
83880-56B00
83840-56B02
part numbers are for 92-95, 5door JX.
try http://www.euro4x4parts.com/parts/ (if you live in europe). search the above part numbers, pretty cheap with good quality.
(12-26-2019, 05:25 AM)kthnos Wrote: front inner:
83850-56B00
83860-56B00
front outer:
83810-56B00
83820-56B00
rear inner:
83870-56B00
83880-56B00
rear outer:
83880-56B00
83840-56B02
Thanks for the part numbers. looks like a lot of money to change them all. Any alternatives to buying new?
83850-56B00
83860-56B00
front outer:
83810-56B00
83820-56B00
rear inner:
83870-56B00
83880-56B00
rear outer:
83880-56B00
83840-56B02
should be about 20 euros per piece, and you only need the exterior ones as i understood. 80 euros total (+shipping) for all 4.
not sure you should try getting used ones, and i doubt they will be any cheaper.
