Sidekick 4-door window seals - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Sidekick 4-door window seals (/thread-sidekick-4-door-window-seals) |
Sidekick 4-door window seals - Xoloski - 12-25-2019 I have a '92 JX, 4 door sidekick. The window seals (rubber seal between the glass and outside door window opening) are brittle and falling apart. I have looked and not found replacements. What have you done to replace or rebuild these seals to keep water and dust out of the door interior? RE: Sidekick 4-door window seals - kthnos - 12-26-2019 front inner: 83850-56B00 83860-56B00 front outer: 83810-56B00 83820-56B00 rear inner: 83870-56B00 83880-56B00 rear outer: 83880-56B00 83840-56B02 part numbers are for 92-95, 5door JX. try http://www.euro4x4parts.com/parts/ (if you live in europe). search the above part numbers, pretty cheap with good quality. RE: Sidekick 4-door window seals - Xoloski - 12-26-2019 (12-26-2019, 05:25 AM)kthnos Wrote: front inner: Thanks for the part numbers. looks like a lot of money to change them all. Any alternatives to buying new? RE: Sidekick 4-door window seals - kthnos - 12-28-2019 (12-26-2019, 11:26 AM)Xoloski Wrote:(12-26-2019, 05:25 AM)kthnos Wrote: front inner: should be about 20 euros per piece, and you only need the exterior ones as i understood. 80 euros total (+shipping) for all 4. not sure you should try getting used ones, and i doubt they will be any cheaper. |
