04-01-2015, 03:04 AM
Howdy! I have a 90 tracker 4x4 manual, and i'm trying, and failing to find replacement parts for the shift extension. The broken piece i am trying to replace is part #26 in the diagram of the shift extension found in your FAQ page. The finger snapped off where it sits in the shift forks. Someone had welded it in the past and it re-broke just above the weld (cast metal, break expected there). Short of buying an entire used tranny, does anyone know where i could find just the shift rail finger? or the entire shift extension mechanism?
Im going to attempt to salvage this one when i find time, by drilling out old pin, and welding in a hardened bolt to get by.
I paid $300 for the tracker, and we use it just around the farm, so any suggestions are open, it can be far from perfect.
Thanks for your time and Input!
-jake
-jake
