Threads: 88
Fixkick,
I noticed tonight while backing up that my 95 tracker has no reverse white lights. Is this due to having a MT or are they burned out?
Threads: 21
08-28-2014, 08:25 PM
(This post was last modified: 08-28-2014, 08:29 PM by gorkyb.)
They should have it regardless of transmission type. Hopefully just burned bulbs. If not check and line the backup light switch.
08-29-2014, 12:35 AM
(This post was last modified: 10-03-2014, 08:17 AM by fixkick.)
both tranny have a back switch
a/t PRNLD switch right side of box.
m/t, on top front section. see gallery photos. transmissions.
the shift rail moves to reverse and hits the switch, it closes and 12vdc, is sent to both lamps in the rear.
Threads: 88
Changed bulbs and no joy. Need to look at switch. Is there an adjustment for the switch? Or, is it typically found bad? Replacement switch available?
10-03-2014, 08:03 AM
it dont adjust.
http://www.fixkick.com/tranny/sidekick_d...manual.pdf
page 14 here, ID #2
in a spot very hard to reach.
pull the connector, key on, short the body side connector side, and rev. lamps must glow, if not, leave the switch be and find the open wire fred from here.
suzuki p/n 37610-83001 $28
Fixkick, Im having the same problem with a 91 tracker, 3sp automatic... same part# as mentioned above for this switch???
[size=small]US Federal '91 Geo Tracker Softtop 1.6L 8V 2DR 4X4 3 spd auto CAMI RWAL A/C 158,000 miles[/size]
10-07-2014, 05:03 AM
(This post was last modified: 10-07-2014, 05:09 AM by fixkick.)
the 3speed has a side mounted PRNDL switch, if the input is 12vdc is good and the R pin is dead. the switch is bad. 12vdc ,good, 0v bad, or If like 3- 6v the reverse feed is shorted.
most can be dismounted and cleaned.
item 18 here
see page 6 for schematic of it
http://www.fixkick.com/power-elect/95%20...mps95b.pdf
10-07-2014, 05:31 AM
(This post was last modified: 10-07-2014, 05:55 AM by ORF-tracker.)
Appears to be part # 37720-60A00 or AIRTEX / WELLS Part # 1S5092 (4WD version)
i think any store sells this, for any 3speed,
did you look at rockauto?
your suz. pn is correct for 4wd , 3sp.. 91 to 95.
37720-60A00
(10-07-2014, 08:50 AM)fixkick Wrote: i think any store sells this, for any 3speed,
37720-60A00
I used rockauto for the research (additional part numbers, pics) then found it elsewhere for $60 w/fedex overnight. Was NOT able to get the connectors to disconnect on the old one without tearing off the top of the engine to get access. So I spliced the new one in, soldered it, shrink wrapped it and put it on. All is well. Other than it needs to be adjusted a little, as the reverse lights only illuminate at one far end of the shifter stroke. Its needs to come on in its natural resting spot. I appreciate this thread, really helped.
