Oil overfilled, wasn't before
I checked the oil level recently and to my surprise the oil was half an inch above full mark on the dipstick. It's been parked a lot, it drove about a mile last week, drove a few times before that since the oil change in late May, maybe ~90 miles total. Now, it has a lot of oil leaks, so I was expecting the level to be low if anything. Oil seems clean, no antifreeze I think. Any ideas as to why this happened?
engine oil or tranny?
virtual sig. 1993 16 valve 4 door sidekick what trans? of the 3?
Sorry engine oil. Yes 4dr 16v, and 5 sp. if that matters
if too high, then it was topped off hot.
or overfilled cold.
to check oil , so do in in AM first run, after all oil is in the pan. every drop. (mostly)
or is foamed up, overfilling it can cause the crank shaft to wipe i to foam , a very bad idea. foam done lube rods or mains.
1: over filled
2: short sticked.
3: foamed
4: gas in oil
5: other fluids there. ouch
6: filled hot.
7: filled running , OMG.
i hope it is 2
The oil was stone cold, not run in a week. I could be wrong, but I was pretty sure the oil level was alright when I last checked it. So I think it would have to be something catastrophic that has gone wrong (I drove it at most 40 miles since the last time I checked the oil level), or some kind of measurement error/ problem with the stick.
What is short sticked?
1993 4 door JX 16v fed manual all stock
stick jammed, short sticked
there is no place for engine oil to hide. not overnight, oil is checked on a cold engine, after drain down..
on the road, very carefully, just keep it above the low line., then check it in AM first thing, key in pockets.
Users browsing this thread:
