Oil overfilled, wasn't before - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Oil overfilled, wasn't before (/thread-oil-overfilled-wasn-t-before) |
Oil overfilled, wasn't before - Sylvanite - 08-17-2014 I checked the oil level recently and to my surprise the oil was half an inch above full mark on the dipstick. It's been parked a lot, it drove about a mile last week, drove a few times before that since the oil change in late May, maybe ~90 miles total. Now, it has a lot of oil leaks, so I was expecting the level to be low if anything. Oil seems clean, no antifreeze I think. Any ideas as to why this happened? RE: Oil overfilled, wasn't before - fixkick - 08-17-2014 engine oil or tranny? virtual sig. 1993 16 valve 4 door sidekick what trans? of the 3? RE: Oil overfilled, wasn't before - Sylvanite - 08-18-2014 Sorry engine oil. Yes 4dr 16v, and 5 sp. if that matters RE: Oil overfilled, wasn't before - fixkick - 08-18-2014 if too high, then it was topped off hot. or overfilled cold. to check oil , so do in in AM first run, after all oil is in the pan. every drop. (mostly) or is foamed up, overfilling it can cause the crank shaft to wipe i to foam , a very bad idea. foam done lube rods or mains. 1: over filled 2: short sticked. 3: foamed 4: gas in oil 5: other fluids there. ouch 6: filled hot. 7: filled running , OMG. i hope it is 2 RE: Oil overfilled, wasn't before - Sylvanite - 08-19-2014 The oil was stone cold, not run in a week. I could be wrong, but I was pretty sure the oil level was alright when I last checked it. So I think it would have to be something catastrophic that has gone wrong (I drove it at most 40 miles since the last time I checked the oil level), or some kind of measurement error/ problem with the stick. What is short sticked? RE: Oil overfilled, wasn't before - fixkick - 08-19-2014 stick jammed, short sticked there is no place for engine oil to hide. not overnight, oil is checked on a cold engine, after drain down.. on the road, very carefully, just keep it above the low line., then check it in AM first thing, key in pockets. |
