Geo Tracker Factory Service Tools....
I finally put together the last piece to the Geo Tracker factory tool set. I got burned buying this set since he said the wheel bearing tool was included, but I found out it was not. If you purchase one, it is located in the upper right hand corner of the set. It's a $50 item separately. Had to get the brake bleeder, wheel bearing tool, injector tool and an axle tool separately. The injector tool is not common on the sets offered which I have seen. One surprise is that the set needs a J-8092 arbor to use many of the seal and bearing tools. This item is not cheap and I ended up buying an entire set to obtain it. Otherwise, it's a $40 item if you can find it.
Here are some photos... Vitalie was the one who published a note making me aware of this set! Thanks Vitalie!
[Image: Tools1_zps0bf2af01.jpg]
J-8092 Arbor and misc parts...
[Image: tools2_zps26d0bff6.jpg]
nice set
the front axle , tool is cloned. its on ebay for 50 bucks.
the real tool is over $100 now.
Yes, I bought the clone! It appears to be very high quality.
