Geo Tracker Factory Service Tools.... - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Geo Tracker Factory Service Tools.... (/thread-geo-tracker-factory-service-tools) |
Geo Tracker Factory Service Tools.... - cosmic_splatter - 09-09-2014 I finally put together the last piece to the Geo Tracker factory tool set. I got burned buying this set since he said the wheel bearing tool was included, but I found out it was not. If you purchase one, it is located in the upper right hand corner of the set. It's a $50 item separately. Had to get the brake bleeder, wheel bearing tool, injector tool and an axle tool separately. The injector tool is not common on the sets offered which I have seen. One surprise is that the set needs a J-8092 arbor to use many of the seal and bearing tools. This item is not cheap and I ended up buying an entire set to obtain it. Otherwise, it's a $40 item if you can find it. Here are some photos... Vitalie was the one who published a note making me aware of this set! Thanks Vitalie! ![]() J-8092 Arbor and misc parts...
RE: Geo Tracker Factory Service Tools.... - fixkick - 09-09-2014 nice set the front axle , tool is cloned. its on ebay for 50 bucks. the real tool is over $100 now. RE: Geo Tracker Factory Service Tools.... - cosmic_splatter - 09-09-2014 Yes, I bought the clone! It appears to be very high quality. |
