09-09-2014, 06:02 AM
I finally put together the last piece to the Geo Tracker factory tool set. I got burned buying this set since he said the wheel bearing tool was included, but I found out it was not. If you purchase one, it is located in the upper right hand corner of the set. It's a $50 item separately. Had to get the brake bleeder, wheel bearing tool, injector tool and an axle tool separately. The injector tool is not common on the sets offered which I have seen. One surprise is that the set needs a J-8092 arbor to use many of the seal and bearing tools. This item is not cheap and I ended up buying an entire set to obtain it. Otherwise, it's a $40 item if you can find it.
Here are some photos... Vitalie was the one who published a note making me aware of this set! Thanks Vitalie!
![[Image: Tools1_zps0bf2af01.jpg]](http://i957.photobucket.com/albums/ae59/johnhovan/Tools1_zps0bf2af01.jpg)
J-8092 Arbor and misc parts...
