how to communicate Kia Pride 20pin Diagnustig connector
Hi
Good day
I have Care KIA pride include Ecu Siemens and 20pin diagnostic connector under the hood
ecu picture
[Image: 0_0_productGfx_3c4ee38026ff77bacda28957ac84bc23.jpg]
Diagnostic Connector Detail
http://pinoutsguide.com/CarElectronics/k...nout.shtml
I need How to Connect to this model For see sensore detail and ecu parameter ?
Can you Help Me?
(08-25-2015, 10:00 PM)fixkick Wrote: step one, get the car schematic (need full information , year, make, model, driveline options car)
The ECU/PCM schematic covers this.
the FSM for the exact car shows how to test all sensors. on most cars. (a big clue there)
I'm not sure KiA Prides are sold here. so no book here, USA.
the full story on PRIDE is here
its complex.
what country? what year,? 1.3L engine. is only clue,, seems this engine started in 1994....?? ended in 2000?
and is a ford/Mazda B3 engine? with German ECU.
Hi
Thank you Dear fixkick
I can only find specification in internet here
http://www.automobile-catalog.com/car/19..._1_3i.html
Also this
https://en.wikipedia.org/wiki/Ford_Festiva
and here trouble code info
http://www.troublecodes.net/kia/
About Schematic i have only this map
[Image: viewer.php?file=x3xlsddpsy496ypno0hy.png]
This pic on my care Engine
http://www.overpic.net/viewer.php?file=x...11mppq.jpg
I have heard Hi scan pro Diagnostic scan tools Compatible kia 20pin
Hi
Very thank you Dear fixkick
This model Car made by iran Saipa Company. Years Among 1996~2003
i have original software H scan pro compatible on PC and windows
This pic on software and show mission KIA General / Pride. please see
http://www.overpic.net/viewer.php?file=x...1q6cpf.jpg
http://www.overpic.net/viewer.php?file=x...06zl0w.jpg
But i dont know witch interface compatible this software and will work .
One said to me, FT232RL White DTR Pin Can Communicate this model . But i Build Interface and Test This . Note Work Huh
Sorry for my bad English
(08-26-2015, 10:00 AM)fixkick Wrote: you'd have to talk to the maker, of that tool.(software/hardware)
the FT3232 is a virtual RST232 USB Uart port. (for serial data transmission and reception)
it transmits on 2 lines , TX and RX .
your car is 1 line i bet., this takes a special driver to make that work. very special. (bidirectional mode) ALDL like.... i bet but for sure dont know, only KIA knows this....
the tool must know who to communicate this ECU at those signalling levels. (0 to 5v? or?) more.?
and the hand shake
then it must know the command sets .
to scan this PCM you need to find a tool maker that supports this exact engine and PCM. a tall order in most cases like this.
you need to find someone that is scanned your same car, that in UK
someone there, a
ok the wiki said
In 1993 a relationship with KIA began, and production of the Kia Pride commenced
i and no idea Kia's made there. wow,...
keep in mind, there are vast numbers of cars made by KIA
just because one ECU communicates to one TOOL, does not mean they all do. not even close...
Hi
Dear fixkick . I find IC MC33290D . This ic Support Bi Directional Mode ( According to you) . do you think this ic is support my Care ?
And i Try to find How to use Handshake on this protocol
Hi
Dera fixkick . very very thank you For answer me . And Sorry For Catch Your Time
Excuse me For my bad English
this answer was perfect , But me English is very Weak . i Don't Understand Good You'r Mean
If I'm not mistaken you'r mean is My Care Support ISO 9141-2 ?
And i use IC MC33199 ?
MR: fixkick . i have Original software for Kia . if i send this software to you . and tell you mission of my care on this software . Can you understand ? this can be help you For know detail of my care ?
abut K line . my car Diagnostic connector included only L-Line pin 19 . k line is empty
http://www.mediafire.com/view/42124hxuc5...%DA%AF.jpg#
also . i think this model of ecu Siemens on my care . Very similar to Fenix 5 .
i find this
http://www.volvoforums.org.uk/showthread.php?t=196012
If I 'm wrong ?
REDUX2
the photo tells me zero , unless i work at KIA and have access to secret documents. E)
my web site only covers USA and Canada cars. period. can to other Suzuki countries. yes.
you can ask a question here on any car, it's ok
but you failed to say 2 things.
what factory code.
where is car, what country (iran)
and what is the market code. (unknown)
post all body tags ECU photos are useless... (all those codes on it are secret (cept the one KIA indexes on there parts catalogs, different in every country)
as you many ,not know
in some countries you can buy a car from JAPAN direct or from Korea, that is marked code for Korea drivers only (market Korea)
so not read USA pages on USA cars, I see you doing that over and over, you car is not a USA car. not in the least.
Thank's
you don't worry about EXE File . Because i Download . here
in this software Section kia pride
what scan tool are you attempting to use.? i 'don't try . Because here is very expensive . But here Many company Make Scan tools . And i see connect to the my care in the service center For Regulation and tuneup
what car, A KIA Pride. Kia Pride 1.3 Liter 4 Cylinder
what year car? in iran between 2002 ~ 2004 in Europa Between 1995 ~ 1998 i Think
located in what country. this car.? in Iran . Because I'm living in Iran .But this care Copy From Ford festiva . i Think
Oh my god
thank you My friendSmile
I did not think This value is hard Confused
ok
i think best way is i go to maker scan tools . and i request help me.
Dear fixkick . About VIN pin . How to Find this pin for my care ? Carved on the body ? Or the document ... ØŸ
still no body tags posted
like this one
[Image: 95-H20A-VG.jpg]
there are others, and the vin
and all matter.
all tags tell you this.
where was it made (factory)
what year made,
what market was it made FOR.
what engine is there, ford, Mazda, or Kia.
what transmission.
what smog rules does it comply with.
tire pressure and size, I dont care.
the car is full of TAGS. post them.
all we know its it resides in IRAN, WHICH I THINK IS NOT IMPORTANT, ONLY THE ABOVE MATTER.
i find 17 digit VIN Number on the Document . But i think not standard . Because Great in Iran
But i fine this
https://www.google.com/url?sa=t&rct=j&q=...rwwxPfX9JA
i read this pdf . and see . this
[Image: v7glqv.jpg]
Do you think kia pride has KWP ISO Support ?
and About Melco protocol . I do not know anything
