High idle regardless of whether it is cold or hot
Hi to everyone! I'm new one here and first apologize for my english. Many useful information draw my attention when I tried to find solution for problem.
I have Suzuki Vitara 1995 1.6 16V, convertible, 178k km, MT, 4WD, built in Spain.
Engine have installed liquid petroleum gas which goes directly to airflow tube and on the same injectors as petrol. Usually people here install liquid petroleum gas (LPG) (0.6 USD/per liter) because it's twice cheap then petrol (about 1.2 USD/per liter).
When I bought it two months ago, fuel system was crapy and dirty. Engine shaked and got this ups and downs when idle running on petrol (1100 to 1800 rpm). He didn't have power to climb up some steep hills etc. When it's on LPG idle speed was normal (around 800 rpm) and got much more power than on fuel. It is very common problem here with dual fuel system (DFS) cars, because engine don't run much on petrol so whole system get rusty and stuffy. So I decided to fix things up with fuel system, low RPMs, gain more power, low consumption etc.
First step - ultrasonic cleaning of injectors > result: some 20% better performance when accelerating and stabilize idle speed without ups and downs (on LPG > 800 rpm, on FUEL > 1200 rpm). So, didn't solve problem with high idle rpm on fuel.
Second step - changing spark plugs (NGK) and fuel filter (JAPANPARTS). > result: beast reborn - much better performance on the road driving on both systems (fuel and lpg). Still have problem with high rpm's on fuel.
Thirds step - using EGR spray to clean airflow and EGR and physical cleaning of throttle. So throttle was dirty (black fat like things in)> result: maybe some gain of performance but now engine goes way to high even on LPG.
RPMs on fuel - around 1800 (hot and cold either), on LPG - 1000 (hot and cold either). LPG has it's own idle control valve and can easily switch to lower rpms but I still have problem with fuel.
Now i doubt on two things that pushing ECU to idle so high:
- vacuum - false air (don't know how to solve that)
- some of the sensors (MAS, ICS etc).
Did someone had similar trouble?
(09-20-2017, 11:48 PM)dell_mare Wrote: Hi to everyone! I'm new one here and first apologize for my english. (no blame,you most welcome)
When I bought it two months ago, fuel system was crappy and dirty. (what fuel system the old petrol or new LPG)?
first off doing this to any EFI system this dumb is not easy at all.
The ECU goes to limphome and spark is retarded for ever, ,bad bad that.
oh boy, you want to bounch back and forth between 2 radical different fuel sytems
sure and now the petrol side is bad, injectors packed with junk, they have 10 micron screens that just hate junk there.
- vacuum - false air (don't know how to solve that) I do but never on LPG
Did someone had similar trouble? ( sure fast hot idle problems, endless ) and cures for all. on PETROL only.
the 16v ECU is a MAF based fuel system called AIR DENSITY SYSTEM.
The maf tells the ECU air flow and the ECU then calculates fuel rates.
The ECU watches RPM and temp. and controls hot rpm all the time, on petrol. with LPG the ECU will go nuts, totally nuts. so I will not talk about LPG ever.
just fuel or petrol. (gasoline here its called and same)
dual fuel cars are fully engineered, your is not 'hacked, (no lie there are great LPG systems and too many to imagine, ) but not with fuel. petrol legacy there.
my guess on fuel , RPM failures:
the ISC is dead. it can't control RPM at all, due to TV set wrong. or ISC jammed. open.
HOW I find this is ,
make sure the IAC below the main throttle body had hot water flowing there 82c and is not blocked, if it stall there the IAC sticks open,
IAC is closed 100% 65C and higher. (its a thermal device only for idle are flows)
the ISC on the front left plenum box, is electic and 100% ECU modulated. (non thermal)
it must not stick . either one,
ISC if its duty cycle is seen at 100% on scan tool that means (or 0) that means there is air leaks, or TV stuck open .
The TV plate on this car is 99.99%closed, at all times foot OFF the petro, right foot pedal.
if not its been hacked some way, only 3 things control idle speeds never TV, its closed
TV is closed 100% (.005" open is zero open)
IAC closed hot.
ISC modulating at 50% hot idle scanned, if not set bleed to 50%
that air bleed screw set correctly.
It is real hard to fix OBD1 cars lacking a scan tool
OBD1 cars have very punishing , limphome mode, if you try to fool the ECU. like LPG can,
a good LPG system would replace fuel and spark i bet yours dont run custom spark does it.
THE OBD1 limphome retarded spark is horrible, and way less in 1996 and newer here at OBD2 changes.
Know to that spark advace is 3D, not simple on EFI. its based on RPM AND LOAD.... (and mode, if in limphome , its bad)
we get up to 40 degree's advance (sparK) if working right. and never in limphome.
a best dual fuel systems, as seen on new cars..
is a new ECU that sthe engine in both modes correctly
for sure in LPG, it must be tuned for LPG spark needs.
based on fuel type, load and rpm. and driver demand,.'
so what things did you add to the stock car .>
sure LPG
but did it add air valves there, and it yes are those turned off, in petrol mode?
When I bought it two months ago, fuel system was crappy and dirty. (what fuel system the old petrol or new LPG)? petrol system was crap..gas is upgraded and attested so it works perfectly.
Zero step - Fuel pump changed
Second step - changing spark plugs (NGK) and fuel filter (JAPANPARTS). > result: beast reborn - much better performance on the road driving on both systems (fuel and lpg). Still have problem with high rpm's on petrol.
- vacuum - false air (don't know how to solve that) I do but never on LPG you mean, LPG want run if there is a problem with vacuum - false air?
Did you mean driving only on petrol is cure for all? Smile
The ECU watches RPM and temp. and controls hot rpm all the time, on petrol. with LPG the ECU will go nuts, totally nuts. so I will not talk about LPG ever. Ok, that's for sure, everyone complains that LPG ruined they petrol systems.
just fuel or petrol. (gasoline here its called and same) Apologize for that - petrol.
IAC closed hot.
that air bleed screw set correctly. Thank you very much for this elaboration. I'm not sure that I'm the man for doing all of these checks and repairs. I will go to one of my local mechanics.
Today I tried something. Just put my hand in way to shut air intake and see how will engine react. Rpm's got down immediately Is there any solution in checking some kind of dirty in MAF or buying new MAF (even if I saw your comments about cloned MAF)? There is one https://www.aliexpress.com/item/Factory-...81260.html
(09-21-2017, 02:56 AM)fixkick Wrote: a best dual fuel systems, as seen on new cars..
sure LPG
I didnt add anything. LPG was already added, tuned, and attested (by traffic law here). I dont know about those valves. Maybe I can upload some pics to show how LPG installations look like.
Anyway I forget to tell about Vitara driving performance:
Max speed I did: 130 kmh (80 mph) - there is a long way to go in fifth gear to get that speed.
Mileage driven: 1242 miles in a month / oil color didnt change and oil level is the same from start
Acceleration to 100 km/h: not tested
the LPG, must change lots of things... i'd bet it's not just LPG injection added to the air horn.
lots more... to it, than that.
many LPG kits, have added an air VALVE (Idle speed control device) to one of the many possible vacuum lines or ports. on the plenum.
all this is a custom modification to a stock petrol car.
and there are many makers of kits, all very different.
it also cuts petrol fuel some way.
and monitors spark some way to be sure LPG does not flow on a stalled engine or after a wreck.
my guess, is it uses its own added MAP sensor to calculate LGP flows.
some add and EGT exhaust gas sensor to regulate LPG flows,
if the LPG mode, fools the ECU, as it surely will
the ECU goes to limphome mode.
retarded timing, and idle controls dead.
i bet the ECU is complaining big time, in LPG mode, ever scan it to see that>?
DTC codes, 13to 53. on this ECU. 12 is normal.
here are the limphome rules
Ive never run test like this. (but have done this on a bench)(
but I'd say with car started in LPG mode.
the ECU thinks car is push started, or was started by coasting down a hill and some one released the clutch and is now running,
It injects fuel when you do that so, id bet LPG has fuel cut device there, preventing that.
the ECU would get real lost like that, unable to control fuel at all, in anyway... and go to limphome mode.
It all gets down to one fact, how to fool any OBD1 Petrol stock ECU..?
In petrol mode your idle controls are failing 800 rpm is hot RPM, AC off.
So why not insert the diagostic jumper see if there is a DTC code.
(09-22-2017, 08:14 AM)fixkick Wrote: the LPG, must change lots of things... i'd bet it's not just LPG injection added to the air horn.
Thanks for this suggestions. Maybe I will search someone who have OBD1 diagnose to check whole system. The more you talk about LPG influence on petrol system,
Today was around 13 celsius degrees here (15 F) and I capture a video of engine just after starting.
https://www.youtube.com/watch?v=dVGA-5iqbdY
It run balanced - 1600 rpms on petrol, 1100 on LPG. Before that I take down MAF and air filter to see if there is some dirt or anything else that blocks air stream. Nothning.
What happens if I just plug out dome fuse and get back when battery is plugged in? I saw it will reset ECU?
Maybe I found reason for my problems. It's MAF obviously. Disconnected power from MAF while engine was running and nothing happens - so MAF is dead. I think I will order new one from China. https://www.aliexpress.com/item/Factory-...8.8.Lvdmyy
(09-23-2017, 06:21 PM)dell_mare Wrote: Maybe I found reason for my problems. It's MAF obviously. Disconnected power from MAF while engine was running and nothing happens - so MAF is dead. I think I will order new one from China. https://www.aliexpress.com/item/Factory-...8.8.Lvdmyy
I received new MAF from China. Replaced old one, and result is:
- When cold started engine idles balanced - RPM's are around 1100 (@10 degrees Celsius) - looks like high rpms problem is fixed but....
- When engine get to working temperature (hot) idle RPM's are below 1000 but stalls and going below 500 and lower, pushing engine sometime to turn off when idle..so I must give some throttle to stay on.
Is it possible that old (unchanged) air filter can do this or maybe it's something else?
every $25 maf from china ive seen (new from suzuki is $1000)
open up insides, via lid,off
all in there was junk. pure junk , toy grade, hope yours is not.
our pro grade maf , refurbs from the famous co. is $197
CARDONE.
http://fixkick.com/buy-parts.html#MAF16
the maf also makes idle work, and guess what, tinker-toy mafs do not work at idle when air flows are small, only the best work there.
http://www.rockauto.com/en/catalog/suzuk...ensor,5128
HOT ! all comments hot engine.
again no? CEL blink codes, in Diag jump mode.?
The idle ISC valve must work or there will be no idle controls, if jammed.
the idle switch must close.
it most not be in limphome mode or there will be no idle controls.
if the air cleaner looks ok, it is.
good luck with cloned parts, some are useless. ford sure expensive precision calibrated parts like this.
