GL-4 or GL-5 for Transfer Case
(09-29-2020, 03:43 AM)fixkick Wrote:
(09-28-2020, 12:05 PM)qrasmeidirt Wrote:
(09-27-2020, 10:08 PM)fixkick Wrote: Synchromesh Transmission Fluid(GM Part No. U.S. 12345349, inCanada 10953465).
this is the GM spec for GL4 (used by Suzuki in the CAMI plant in Canada)
note the same numbers here
https://www.pennzoil.com/en_us/products/...fluid.html
Axle Lubricant(GM Part No. U.S. 12345977, ini Canada 10953482) orSAE 80W-90 GL-5 gear lubricant.
977 is it ,
https://www.redlineoil.com/75w90-gl-5-gear-oil
https://www.amazon.com/dp/B007WVI5G6?tag...th=1&psc=1
GL5 yes, GL4 no.
https://www.amazon.com/dp/B000IG20RC?tag...th=1&psc=1
off the shelf here in town.
GL4/5 in one jug., amazing, no?
https://www.walmart.com/ip/Valvoline-Hig...t/23325574
texas Ashland oil. via Valvoline. ( my my guess is special new EP , additives used allow that)
Does walmart ship that valvoline 80w-90 gear oil GL4/5 worldwide??
Can the Valvoline-High-Performance-80W-90-Gear-Oil-1-Quart GL4/5 be used in both transfer case and front/ rear differentials??
i can speak any company or shipper, only you can easy, click add to cart then answer the questions bingo your answer.
question #2 yes.  that is why it has both GL4 and 5 on the label , and means just that, yes.
977 is it ,
GL5 yes, GL4 no.
I come across this oil, could you help examined and confirmed it can be used in both the differentials and the transfer case of the Sidekick Sport??
https://i.imgur.com/UfbygBW.jpg
https://i.imgur.com/tJv1KDi.jpg
