07-11-2015, 10:56 PM
My old radiator started weeping and then leaking in two spots last week. I ordered a radiator from Amazon after measuring and checking specs the best I could. This is the one I purchased http://www.amazon.com/gp/product/B0073ME..._at_prodpg with shipping it cost $59.94 from Shephard Automotive
It arrived yesterday and fit perfectly The radiator has the fittings for the auto trans lines to the oil cooler built into the radiator. For the manual transmission you just ignore them. You will need a radiator cap, the original metal bolt clamps from the top corners, and the rubber cushions at the bottom mount points. The plastic fan shroud mounted without any problems too!
The only issue is the old radiator cap didn't fit which I was warned about before ordering. I open up the bottom tabs on the old cap so I could do a quick road test and it worked. Now I'm off to the local parts store to find a new radiator cap.
1994 Geo Tracker 2dr, soft top, 2wd, 5-speed, with 8-valve engine
