Found an inexpensive replacement radiator - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Found an inexpensive replacement radiator (/thread-found-an-inexpensive-replacement-radiator) |
Found an inexpensive replacement radiator - tbb10785 - 07-11-2015 My old radiator started weeping and then leaking in two spots last week. I ordered a radiator from Amazon after measuring and checking specs the best I could. This is the one I purchased http://www.amazon.com/gp/product/B0073ME53G?redirect=true&ref_=cfb_at_prodpg with shipping it cost $59.94 from Shephard Automotive It arrived yesterday and fit perfectly The radiator has the fittings for the auto trans lines to the oil cooler built into the radiator. For the manual transmission you just ignore them. You will need a radiator cap, the original metal bolt clamps from the top corners, and the rubber cushions at the bottom mount points. The plastic fan shroud mounted without any problems too! The only issue is the old radiator cap didn't fit which I was warned about before ordering. I open up the bottom tabs on the old cap so I could do a quick road test and it worked. Now I'm off to the local parts store to find a new radiator cap. 1994 Geo Tracker 2dr, soft top, 2wd, 5-speed, with 8-valve engine RE: Found an inexpensive replacement radiator - fixkick - 07-12-2015 the rad sold is not pure suz. spec. its got a non stock cap, i had to (in store) look at every cap to find the match. but there rad was all brass, way better than any plastic top rad. for sure. RE: Found an inexpensive replacement radiator - tbb10785 - 07-17-2015 Quick update. Original OEM radiator cap will not fit. Shepherd auto replied to my question and said a Stant #11233 would fit. My local auto part store didn't carry this brand but used the info to cross reference to a Murray #7516 brand cap which fit perfectly. These caps fit a 93 Geo Storm for help in looking up this part. RE: Found an inexpensive replacement radiator - fixkick - 07-18-2015 thanks, will add it to the hard to find parts page. now. thanks a bunch. i knew once, then forgot,..... RE: Found an inexpensive replacement radiator - tbb10785 - 07-18-2015 (07-18-2015, 12:31 AM)fixkick Wrote: thanks, will add it to the hard to find parts page. now. Glad to help! Owning Tracker is getting to be similar to a motorcycle I owned 15 years ago an MZ Skorpion. Right never heard of it so you had to be creative to get the right parts. Luckily the motor was Yamaha design so motor parts were easy. Question - Does the coolant system need to be bleed? I've had some motorcycles which needed to be bleed after drain & fill of the coolant. Thanks! I should note that the radiator is avaliable directly from Shepherd Auto parts if you don't have an Amazon account. This should be a link to the one I purchased http://www.shepherdautoparts.com/autoparts/radiator/geo/tracker/1994/w5bDl8OVw5fDk8K7w5TDl8OVw5fCog==.htm Interesting there's more details on the Amazon listing than on the direct company website. |
