09-18-2014, 02:26 AM
Fixkick master index...Version 1
Suzuki Part Number Reference
http://www.fme-cat.com/Application.aspx?...ngine&ga=Y
G16 Engine Parts Exploded View
https://monsterfactoryparts.com/parts/19...CallOut=28
Pulling 16v Head
http://www.fixkick.com/engine/head-pull/...cam-locker
Depressurizing the fuel system the easy way.
http://www.fixkick.com/INJECTORS/depressure.html
Windshield Wiper Troubleshooting
http://www.fixkick.com/wipe-wash/index.html
Engine Issues
http://www.fixkick.com/index1.html
Tune Up
http://www.fixkick.com/IGN_timing/tune-ups.html
Belts
http://www.fixkick.com/belts.html
Timing Belt
http://www.fixkick.com/t-belt/tbelt-index.html
Suzuki TSB on Timing Belt
http://www.fixkick.com/All-Pdfs/TSB/89-96crank-bolt.pdf
Repairing Damaged Crank Key
http://www.fixkick.com/t-belt/damage/index.html
Bad and Repaired Crank Cogs and Snouts
http://www.fixkick.com/t-belt/snouts/html/image_1.html
Locking the Crank in place
http://www.fixkick.com/engine/myclutch/f...locks.html
EGR Thermoprobes
http://www.fixkick.com/EGR-Gen2a.html#thermoprobe
Setting Valve Lash
http://www.fixkick.com/t-belt/LASH/Lash16v.html
Repairing a damaged Key
Dash Lamps
http://www.fixkick.com/buy-parts.html#Bulbs
Removing the Dash Cluster
http://www.fixkick.com/power-elect/clust...r-pull.pdf
Pulling the Tranny
http://www.fixkick.com/tranny/clutch/new...howto.html
Hard to Find Parts
Torque Specs
http://www.fixkick.com/specs/torque1.html
Adjusting Belts
Fuel System Tests
http://www.fixkick.com/INJECTORS/pump.html
Engine cranks and will not start
http://www.fixkick.com/nostart-flow/nost..._ways.html
Poor MPG
http://www.fixkick.com/MPG.html
Engine making noise
http://www.fixkick.com/NOISE.html
Wiring a trailer light
http://www.fixkick.com/trailer-wiring/trailer.html
Idle Speeds are wrong
http://www.fixkick.com/IDLE-AIR/idle-index-home.html
Fixing Idle Problems
Finding Air Leaks
http://www.fixkick.com/IDLE-AIR/pure-leaks.html
Someone messed with idle stop screw
http://www.fixkick.com/fresh-air/screwed-again.html
ECU Capacitor Leak Issue Causing no start
http://www.fixkick.com/ECU/ECU.html
ECU Clicking Issue
http://www.fixkick.com/ECU/clicking/clicking.html
Wheel Bearings
http://www.fixkick.com/hubs/FW_BEARINGS.html
Dropping the Oil Pan on 4x4
http://www.fixkick.com/axles/Pan-drop/pandrop.html#cv
Pulling 16v Head
Engine Issues
Tune Up
Belts
Timing Belt
EGR Thermoprobes
Setting Valve Lash
Dash Lamps
Pulling the Tranny
Hard to Find Parts
Torque Specs
Adjusting Belts
Fuel System Tests
Poor MPG
Engine making noise
Finding Air Leaks
ECU Clicking Issue
Wheel Bearings
