Fixkick master index...Version 1 - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Fixkick master index...Version 1 (/thread-fixkick-master-index-version-1) |
Fixkick master index...Version 1 - cosmic_splatter - 09-18-2014 Fixkick master index...Version 1 Suzuki Part Number Reference http://www.fme-cat.com/Application.aspx?year=1995&make=GEO&model=TRACKER&cat=Engine&ga=Y G16 Engine Parts Exploded View https://monsterfactoryparts.com/parts/1995/Suzuki/Sidekick/JS?siteid=217481&vehicleid=187789&diagram=F750035&diagramCallOut=28 Pulling 16v Head http://www.fixkick.com/engine/head-pull/head-pull.html#cam-locker Depressurizing the fuel system the easy way. http://www.fixkick.com/INJECTORS/depressure.html Windshield Wiper Troubleshooting http://www.fixkick.com/wipe-wash/index.html Engine Issues http://www.fixkick.com/index1.html Tune Up http://www.fixkick.com/IGN_timing/tune-ups.html Belts http://www.fixkick.com/belts.html Timing Belt http://www.fixkick.com/t-belt/tbelt-index.html Suzuki TSB on Timing Belt http://www.fixkick.com/All-Pdfs/TSB/89-96crank-bolt.pdf Repairing Damaged Crank Key http://www.fixkick.com/t-belt/damage/index.html Bad and Repaired Crank Cogs and Snouts http://www.fixkick.com/t-belt/snouts/html/image_1.html Locking the Crank in place http://www.fixkick.com/engine/myclutch/flywheel-locks.html EGR Thermoprobes http://www.fixkick.com/EGR-Gen2a.html#thermoprobe Setting Valve Lash http://www.fixkick.com/t-belt/LASH/Lash16v.html Repairing a damaged Key http://www.fixkick.com/t-belt/damage/index.html Dash Lamps http://www.fixkick.com/buy-parts.html#Bulbs Removing the Dash Cluster http://www.fixkick.com/power-elect/cluster-pull/1994cluster-pull.pdf Pulling the Tranny http://www.fixkick.com/tranny/clutch/new-clutch-howto.html Hard to Find Parts http://www.fixkick.com/buy-parts.html Torque Specs http://www.fixkick.com/specs/torque1.html Adjusting Belts http://www.fixkick.com/belts.html Fuel System Tests http://www.fixkick.com/INJECTORS/pump.html Engine cranks and will not start http://www.fixkick.com/nostart-flow/nostats_all_ways.html Poor MPG http://www.fixkick.com/MPG.html Engine making noise http://www.fixkick.com/NOISE.html Wiring a trailer light http://www.fixkick.com/trailer-wiring/trailer.html Idle Speeds are wrong http://www.fixkick.com/IDLE-AIR/idle-index-home.html Fixing Idle Problems http://www.fixkick.com/IDLE-AIR/idle-index-home.html Finding Air Leaks http://www.fixkick.com/IDLE-AIR/pure-leaks.html Someone messed with idle stop screw http://www.fixkick.com/fresh-air/screwed-again.html ECU Capacitor Leak Issue Causing no start http://www.fixkick.com/ECU/ECU.html ECU Clicking Issue http://www.fixkick.com/ECU/clicking/clicking.html Wheel Bearings http://www.fixkick.com/hubs/FW_BEARINGS.html Dropping the Oil Pan on 4x4 http://www.fixkick.com/axles/Pan-drop/pandrop.html#cv RE: Fixkick master index...Version 1 - fixkick - 09-18-2014 thanks my main page is indexed by systems functions, just like FSM's are. and the free find , that and advanced search can find anything. unrestricted. the free find , site index has more. not only that , its not restricting to greater than 3 word searches, like other sites. and cant find ECT fore example. you can search this, "1" my pages are simple white pages, no black backgrounds and can be printed. easy. see the search box. see those 3 blue links there. index, sitemap and advanced the first show every word used, in 600 to 1000 pages, A to Z, even omega for ohms is indexed. by word. the site map shows major indexed topic pages. the last is the advanced search and last my search box. not bad for free, huh? see the search box. see those 3 blue links there. not only that you can search my site end to end using google SITE search here is one example of that. format Search |
