(01-30-2017, 11:24 AM)dazedandconfused Wrote: would one off a suzuki car fit? i just did the timing belt on my fathers suzuki esteem ,it had the same motor and it looks like the same manifold so would one off of a car fit?
the FWD and RWD cars, even with near same G16 engines , have different exhaust systems end to end. head to tail
02-02-2017, 03:05 AM
(This post was last modified: 02-02-2017, 10:20 PM by fixkick.)
answer 2,
one can, in most cases fit the down stream exhaust to any headed end,manifold)
custom welded, all the way\
but that rwd header,, would hit things,on FWD car.
no years stated,why?
no car stated, Eg:;the manifold on my G16 sidekick
http://www.fixkick.com/buy-parts.html#factory'
THE ESTEEM LOOKS NOTHING LIKE OURS. NOT EVEN CLOSE
THE 1995(CASE IN POint)has and direct connect CAT there,you miss that?
the esteem uses a dash- 60G10 manifold, radially different
but I could weld up adaptors for most .
but what if that wrong part hits the engine mount.....
you have 3 choices
used man
new man
or aftermarket + mods to fit up
year, 95 to 02 esteem must I look all 7 years/. ouch
my buy parts page covers this.
miss that on the main page too
you look there,see then G16 sidekick p/n there.
dazed what car are you fixing?
14111-
see that prefix,, which one is yours. i cant guess,that.
then google your number and find what it fits,well it it fits,sidekicks,trackers,and vitara'S
the 8v exh, only fits. SE416 suzuki, period
by any other naMES
VITARA
SIDEKICK
TRACKERS
SUNRUNNERS
02-02-2017, 03:13 AM
(This post was last modified: 02-02-2017, 03:19 AM by fixkick.)
DASED
WHY ASK
NOT HAVING A SIGNATURE (click User CP above)
WE CAN NOT GUESS WHAT CAR YOU HAVE.
I dont like reading your 10 post learn that, tired, gaveup.
why not use the buy page, tell use which one you have now. its not 2 manifolds, in 10 years
if you had tools ,you can fit almost anything,
but if cast IROn hits something, not removable that be a show stopper, even for me, most time, other, just hack further and build new , what is in the way. custom.
answers are for OEM fit parts.
all other parts, no idea in the world, and mixed never.
in my cause I build up from scratch CAT back... if that horrid, front 90deg fitting on some 16v is there, I make one from scratch. the stock is NO GOOD and is RECALLEd
02-02-2017, 03:25 AM
(This post was last modified: 02-02-2017, 10:24 PM by fixkick.)
if your read that linked page, there are at least 3 choices there.
1 oem
2 aftermarket.
with restrictions
the aftermarkests,dont fit Oem STOCK EXH.SYSTEMS'
AND MAY FAIL SMOG (calif. mostly)
BUT read aftermarket pages, rules and options, as can change at THEIR desires.... in all cases ,aftermarket ANYTHING, can change, Calmini seems best. with mods.
the real bummer is that DORMAN
makes a $99 8v manifold. OE type, cast Iron.
but not the 16v, , very very sad that.
and suzuki as per usually wants next unborn child.$ almost $400 delivered, and very long wait. + ship time..even longer
