Threads: 2
Well I guess I'll be busy this weekend BTW thanks for the link to monsterfactoryparts.com I'll add that to my list of parts resources. As always you seem to have all the answers. Thanks again wise one.
Threads: 2
Original DTC p0443 but purge valve passed checks on alldata so naturally I started giving the cannister the dirty looks. Turns out you were right I had some loose hose conections and I replaced the gas cap one from NAPA OE style. After that ran scan tool again no more p0443, but a new code was waiting for me P0340 the camshaft position sensor. Now I'm a little upset but glad I can get the sensor within 24hrs. Original symptoms were as follows hesitation and a couple of stalls at idle and of course a mil lamp. Throughout the coure of this my scan tool a P.O.S. i got from a pawn shop some years back crapped out on me. So I've been using my buddys cheap code scanner until I get this resolved.
ah yours is late 96 with purge update called EVAP 2 level system. it has more VSVs than the early car.
nice work,, btw.
340 never lies. the ECU monitors the CPS, full time all the time. it creates spark and injection timing.
340 is that funky CAS sensor behind cam left.(drivers side)
the cheap scan tool is ok on all early OBD2 cars, (very few DTCs on them)
the CAS loves to fail, loves to leak oil (DIY fix works) and loves to heat soak,
unlike the G16B , never ever fails. like TIMEX watch the CPS.
luky for you the timing freeze jumper is still in the engine bay DLC (left strut tower?)
unlike my silly v6, takes a suzuki scan tool to set the thing.
Threads: 2
Well I was angry yesterday now I'm better Just gotta wait on the sensor to arrive no big deal. Thanks for the insight your the best.
id be PO too with bad CAS. thing is expensive. and should last until the bearings inside die, and we have spare bearings too. someone hacked that too.
bless them.
and your SPORT , bless its little parts.
