02-13-2025, 04:55 PM
Hello Fixkick,
I've been driving my 16v powered samurai for a couple years now, and recently has become undrivable any time it rains.
Engine is out of a 1994 suzuki sidekick, CA car. EGR has been blocked off with resistor spoofing the ECU. Alternator has been replaced with GM CS130. No catalytic convertor. (engine had previously run fine with these modifications)
Recently, with any hint of rain (drizzle), the engine tries to flood itself and misfires on all cylinders. Spark plugs are black and wet from overfueling.
cold start rpm is 2000rpm only after tapping the gas pedal, then falls on its face below 1000rpm and nearly stalls. This continues even after engine has warmed up, nearly stalling when under 2000rpm unless holding the pedal open.
There is no CEL, and flashes code 12 when I check codes.
I replaced the cap, rotor, plugs, and wires and air filter when the issue started. No fix.
Additionally replaced the coil as it had over 200k miles on it, still no improvement.
I replaced the o2 sensor, which improved hot idle when not raining, but rains have started again and back to the same overfueling issue.
I assuming compression is good as the engine runs great when it is dry outside (strong 800rpm hot idle).
I am suspecting sensor issues as the issue is intermittent with rain...
I'd appreciate any help with this, and what I should start with checking as I will have some time to work on it this weekend.
Thanks.
Thanks.
