02-06-2022, 02:33 PM
Hi All,
New to this forum...I can see some great stuff here!
I wonder if someone could pls help me?
I'm in Canada and have a 1997 Geo Tracker, 4 door, 1.6 liter, 16 valve, SOHC.
This has a distributor with coil and igniter stuff inside.
I took the distributor cap off and can see a black plastic high voltage (HV) post with brass tip coming out of the distributor that fits inside a tube of the dizzy cap. In the tube of the cap I see a thin diameter wire coil spring. So when re-assembled the spring would press directly onto the brass top of the post mentioned above. In my limited experience I have never seen a spring set up like this and would expect something flat, etc on the end of the spring between it and the brass top of the HV post.
So my question is am I missing a part or is that how it should be?
Thx
Bill
Thx
Bill
