Threads: 36
I will send you the photo of the tool that would be helpful to you!
By the way, do you have any email, the one on your web is no longer work!
Thanks for all the comments.
good news
via email
we found that pin 2 , is the TP pin on the J18
suzuki does not sell a TPS.
but SMP does, for $60 (a very new price, way below $300)
the center pin of the 3 TPS is pin 2. this is throttle angle pin, called TP by suzuki,
its set to 0.5v
hot running engine
and for sure, no fast idle modes on engine/ecu active
hot idle is normal.
then set the TPS to 0.5v. +- 0.15v error. (tolerance its called)
