07-29-2014, 02:39 AM
Is there any inexpensive way to install an anti-theft system? Switch on the fuel pump etc?
thanks,
thanks,
Anti theft system?
thanks, John
07-29-2014, 03:05 AM
sure that is all I have, just a fuel pump wire.
hid the switch well. they will never find it. one trick is a hidden magnetic switch. just a hole somewhere, in a panel or carpet. hidden you insert a mag key and bam the pump is alive. also at air port parking , remove the rotor from dizzy ive parked for 30 days in air ports. so....
07-29-2014, 01:32 PM
fixkick, do you have a source for the switch you are using? Also, did you use a relay or does your switch handle the amperage of a fuel pump?
thnkx. Good tip on airport storage!!
07-29-2014, 11:06 PM
the pump sucks 4amps, normally, or up to 10amps, overloaded. (filter packed)
those switches are hard to find, ill dig that up.
« Next Oldest | Next Newest »
