Anti theft system? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Anti theft system? (/thread-anti-theft-system) |
Anti theft system? - cosmic_splatter - 07-29-2014 Is there any inexpensive way to install an anti-theft system? Switch on the fuel pump etc? thanks, John RE: Anti theft system? - fixkick - 07-29-2014 sure that is all I have, just a fuel pump wire. hid the switch well. they will never find it. one trick is a hidden magnetic switch. just a hole somewhere, in a panel or carpet. hidden you insert a mag key and bam the pump is alive. also at air port parking , remove the rotor from dizzy ive parked for 30 days in air ports. so.... RE: Anti theft system? - cosmic_splatter - 07-29-2014 fixkick, do you have a source for the switch you are using? Also, did you use a relay or does your switch handle the amperage of a fuel pump? thnkx. Good tip on airport storage!! RE: Anti theft system? - fixkick - 07-29-2014 the pump sucks 4amps, normally, or up to 10amps, overloaded. (filter packed) those switches are hard to find, ill dig that up. |
