(11-01-2019, 03:39 AM)charlo Wrote: I replaced the original Suzuki G16A 31400 -60A10 alternator with a G16B 31400-60A20 Alternator in my 89 kick. Was Working ok.then one day drove for about one mile to the gas station. Switched off to fill up. When I tried to switch on after filling up, no swing. battery discharged to about 10.1 volts. Got a jump start and went back home. tested alternator diodes. Got a reading of 0.891. Heard that the reading should be in the range of 0.500 to 800. Do you think that 891 is above the limit?
first test the battery
those diode are silicone diodes, and that .8 barrier region forward bios voltage drop very by temperature.
any good parts store can test the alternator for you for free, on there spin load tester,
but first are:
1: fuses in the big fender fuse box,, if changing out any alternator with battery neg lug connected, you will
blow up those huge fuses. 1 of them.
2: battery tested load tested, good/ bad, 10.0 is bad, tell me one cell is shorted, test the battery. (first charge a battery fully using a charger, then test it , it must be 12v to 12.6v, never 10v;. (unless 100% discharged) the 12.6v reading is a charged fully battery, (normal temps not Alaska)
3; and Alternator is last if all battery cables, good and no corroded ends x4, and not loose ends x 4.
good luck !
