Air flow meter
Hi all i have a 1996 escudo 16v g16a engine. I am looking for a hack to replace the guts of my air flow meter. Air flow no is 13800 58b00 as you know a new one is about 1000 and as for Chinese clones. If there is a way of modifying the air flow that would be great.
Thanks in advance.
there is no hack really (complex it is) but the counterfeit I documented.
is yours bad, ?
what is the purpose of said hack, (a turbo? or , supercharger mod) why does it need hacking,,, ?
first off , Cardone sells a rebuilt. and is 1/3rd suzuki price or less. ask or see my hard find parts page.
here is the most famous hack of all, from your buddies in China., (and was DOA)
http://www.fixkick.com/sensors/china-maf...d-maf.html
There is no modifing on the engine, i am just looking at a cheaper way of getting a good afm cheaper.
Thanks
there is no easy way, (to hack it) we see some folks using MAF of other car, and then a box that changes the flow tables to match suzuki. (not published this)
the 3 ways are used by suzuki , only 2 this 16v
1: the Air flow meter, 567b00 with classic, flapper vain and a pot, variable resistor. (Seen in Europe with special ECU to match it)
2: the Mass AIR flow meter, hot wire, 58b00 like yours, your ECU cant use above. they work quite differently. (used on all USA G16b's 16v here)
3: MAP sensor on all 8valve engines, useless for your ECU. (uses MAP+IAT=RPM to calculate air flow , it does)
I see Walker has one, now. (new offering) Walker is muffler maker, etc.
http://www.rockauto.com/en/catalog/geo,1...ensor,5128
just dont ask Suzuki, they want your next unborn male child.
A1 cARDONE ,IS KNOWN TO BE THE BEST usa REBUILDER . (FAMOUS FOR ecu'S)
here is the flow , i created. using Excel
http://www.fixkick.com/sensors/92-95MAF/EXCEL-ECHO1.jpg
as you can see its non linear, so doing that , is not easy.
ive done lots of hacking here, (even used a leaf blower in it , to measure flows and of course driving and logging data ,driving fast )
It has to be scaled for idle and WOT. for 1600CC. engine.
here is the data driving fast. shifting me. up to 50mph and flogged.
http://www.fixkick.com/my96-16v/MAF-TPS.JPG
