Air flow meter - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Air flow meter (/thread-air-flow-meter) |
Air flow meter - avaconirl - 04-18-2017 Hi all i have a 1996 escudo 16v g16a engine. I am looking for a hack to replace the guts of my air flow meter. Air flow no is 13800 58b00 as you know a new one is about 1000 and as for Chinese clones. If there is a way of modifying the air flow that would be great. Thanks in advance. RE: Air flow meter - fixkick - 04-18-2017 there is no hack really (complex it is) but the counterfeit I documented. is yours bad, ? what is the purpose of said hack, (a turbo? or , supercharger mod) why does it need hacking,,, ? ? first off , Cardone sells a rebuilt. and is 1/3rd suzuki price or less. ask or see my hard find parts page. here is the most famous hack of all, from your buddies in China., (and was DOA) http://www.fixkick.com/sensors/china-maf/cloned-maf.html RE: Air flow meter - avaconirl - 04-18-2017 There is no modifing on the engine, i am just looking at a cheaper way of getting a good afm cheaper. Thanks RE: Air flow meter - fixkick - 04-18-2017 there is no easy way, (to hack it) we see some folks using MAF of other car, and then a box that changes the flow tables to match suzuki. (not published this) the 3 ways are used by suzuki , only 2 this 16v 1: the Air flow meter, 567b00 with classic, flapper vain and a pot, variable resistor. (Seen in Europe with special ECU to match it) 2: the Mass AIR flow meter, hot wire, 58b00 like yours, your ECU cant use above. they work quite differently. (used on all USA G16b's 16v here) 3: MAP sensor on all 8valve engines, useless for your ECU. (uses MAP+IAT=RPM to calculate air flow , it does) I see Walker has one, now. (new offering) Walker is muffler maker, etc. http://www.rockauto.com/en/catalog/geo,1995,tracker,1.6l+l4,1142266,exhaust+&+emission,mass+air+flow+sensor,5128 just dont ask Suzuki, they want your next unborn male child. A1 cARDONE ,IS KNOWN TO BE THE BEST usa REBUILDER . (FAMOUS FOR ecu'S) here is the flow , i created. using Excel http://www.fixkick.com/sensors/92-95MAF/EXCEL-ECHO1.jpg as you can see its non linear, so doing that , is not easy. ive done lots of hacking here, (even used a leaf blower in it , to measure flows and of course driving and logging data ,driving fast ) It has to be scaled for idle and WOT. for 1600CC. engine. http://www.fixkick.com/sensors/92-95MAF/92-95-MAF-testing.html RE: Air flow meter - fixkick - 04-18-2017 here is the data driving fast. shifting me. up to 50mph and flogged. http://www.fixkick.com/my96-16v/MAF-TPS.JPG |
